  1. What am I doing wrong? Running ffmpeg 3.3.2 on mac.
    Command line:
    ffmpeg -i 00800.track_4352.Eng.dtsma Jurassic.flac
    Input #0, dts, from '00800.track_4352.Eng.dtsma':
    Duration: N/A, start: 0.000000, bitrate: N/A
    Stream #0:0: Audio: dts (DTS-HD MA), 48000 Hz, 7.1, s32p (24 bit)
    Stream mapping:
    Stream #0:0 -> #0:0 (dts (dca) -> flac (native))
    Output #0, flac, to 'Jurassic.flac':
    Metadata:
    encoder : Lavf57.71.100
    Stream #0:0: Audio: flac, 48000 Hz, 7.1, s32 (24 bit), 128 kb/s
    Metadata:
    encoder : Lavc57.89.100 flac
    But what I get is 5.1 flac, not 7.1
    The reason I want to do this is so I can import this into audacity, but that also imports the audio as 5.1 not 7.1, so, thought I would use ffmpeg to get straight 7.1 flac so I could then read it in, but no dice.
    Steve
  2. I think the problem was it was not an official build, it was a Macports build. Using ffmpeg from ffmpeg.org worked fine and provided 7.1 output flac.
    Steve
