Title says it all.
Results 1 to 11 of 11
That's like asking what's better for transportation? Car or bike LOL
If you don't know the answer you shouldn't be here. -
h.265 can deliver similar quality at 2/3 to 1/2 half the bitrate of h.264. But it takes more CPU power to encode and decode. Most new devices support both but older devices do not support h.265. For example, regular Blu-ray players do not support h.265.
When I compared them 6 months ago, I thought for lower resolutions (up to 720p), x264 was easily better than x265 at the same bitrate (at least at CRF18 type bitrates). https://forum.videohelp.com/threads/381376-Where-is-the-new-super-codec-%28the-Allianc...29#post2467576
x265 will probably come into it's own for 1080p and up. I haven't looked at the results of the latest MSU comparisons myself yet, but x264 is included. It's interesting when comparing HEVC encoders, x264 is still included as a kind of benchmark. HEVC Video Codecs Comparison 2017
I doubt 10 bit h264 will ever have mainstream hardware player support, whereas it'll probably be standard for h265. -
I've compared them both recently. Using the same overall settings, crf 19, dts core, PGS subtitles. The actual file size was smaller by 400mb. Not a huge difference. Video quality was a bit sharper with better color using hvec x265 8bit.
Even more-so because resolution wasn't specified either.
When I compared CRF18 for the 1024x576 encodes I mentioned in my last post, the bitrates were:
x265 = 3540 kbps
x264 = 4960 kbps
x264, Tune Film = 5166 kbps
So at the same CRF value x265 will no doubt result in a lower bitrate, but when I ran 2 pass encodes and compared them at the same bitrate I still thought x264 looked better. Actually.... it wasn't even a case of "thinking" x264 looked better. The screenshots I posted weren't cherry-picked.
It seems unlikely to me one encoder would result in "better colour" than the other, but my testing so far has only been with sources at 720p or lower resolutions. Chances are at 4k it'll be a different story, in respect to quality vs bitrate. -
how to convert h.265 mkv into h.264
By flannob in forum Newbie / General discussionsReplies: 5Last Post: 5th Mar 2017, 14:48 -
H.265, will it go mainstream or stick to H.264?
By sdsumike619 in forum Video ConversionReplies: 6Last Post: 19th Jan 2017, 02:59 -
H.264 vs x264 and H.265 vs x265
By LeoKac in forum Video ConversionReplies: 27Last Post: 18th Jan 2017, 08:59 -
Shall i take H.264 OR H.265 ?
By hello0 in forum Newbie / General discussionsReplies: 4Last Post: 12th Jan 2017, 11:27 -
H.264 or H.265?
By SameSelf in forum Video ConversionReplies: 29Last Post: 30th Jun 2016, 14:03
