  1. Please can someone help!
    Im not sure if this prob is related to my TV or DVD player!
    When playing DVDs in widescreen I find that the border
    towards the top right of my screen tilts up slightly.
    If I measure the border at the right of the screen, then
    at the top left there is quite a nasty difference.
    I'm running a lead which has SCART that goes into TV that
    splits off into S-Video and Audio L/R, but I dont think its
    that coz it just displays signal.
    It does this on ALL of my PAL region 2 DVDs.
    I dont have an option to adjust vertical shift on my DVD
    player or TV...so what can I do???
    HEEEEELP!
    Thanks for anyone that offers info!
    Much..MUCH appreciated as im going nuts with this.
    Damien
    "If hustling is deviance in the eyes of the lord, then in my realm he is blind"...B*Tip - Back in the day!
    Feb 2002
    The problem is NOT your DVD player, it is your TV. It needs to be aligned. Some TV's have built-in dot matrix patterns that are used in conjunction with correction circuitry. If your not sure how to do this, check your service manual. Your other recourse is to have a service repairman do the adjustment.
  3. Doh!
    I'm going to ring the people that sold me this thing first
    thing in the morning! Lovely Hitachi 32" widescreen, shame
    about this niggling little problem. I never noticed it until
    I started using widescreen media.
    Anyone else know whether adjusting the alignment is a hard
    job????? Could I do it myself?
    Feb 2002
    It's not really that hard, you just have to know how to engage the alignment pattern and where the convergence controls are for your set. Invariably they will be on the front somewhere behind a panel, since you have to be viewing the screen while you make the adjustments. My 65-inch Toshiba utilizes the remote to do the alignment after the pattern is engaged. The instruction manual, however, does not deal with this at all. You have to look at a true service manual to find this info.
  5. Lid off TV set with power going through it ?
    Erm...I think i'll give this is a miss and just ring
    the warranty line or something! They sell me a TV
    that isn't setup for widescreen DVD.....lol...daft!
