The title says it all.
Dynamic GOP means the GOP size varies depending on the content. Usually a new GOP starts at each shot change.
A closed GOP is a GOP in which b-frames only reference other frames within the GOP. An open GOP is a GOP where b-frames at the end of the GOP can reference the i-frame of the next GOP. -
Half frame rate GOP is to speed up decoding - digital receiver switched from channel to channel need to wait until new GOP arrive then it can start decoding - with half frame rate this is literally 0.5 second delay - after all, with newer codecs this requirement was somehow relaxed and seem it is commonly accepted that 1 - 2 second is fine so GOP can be between frame rate and 2x frame rate - this should improve compressibility. In case where stream is stored locally so decoder can quickly navigate over stream (seek) GOP can be even 10 seconds i.e. GOP is 10x framerate (but usually no more than 250 frames).
What's the difference between Frame and GOP(K-frame)?
By immortal192 in forum Newbie / General discussionsReplies: 2Last Post: 31st Jan 2016, 11:26 -
How to properly convert any long GOP files to i-frame intermediate (mjpeg)?
By Clever Sleazoid in forum Video ConversionReplies: 18Last Post: 15th Oct 2015, 02:58 -
GOP Timecode
By Dave1024 in forum Newbie / General discussionsReplies: 0Last Post: 13th Jan 2013, 13:00 -
size of GOP
By maryam209 in forum Video ConversionReplies: 14Last Post: 3rd Nov 2012, 14:48 -
[Help] Gop Structure
By toryang in forum Video ConversionReplies: 17Last Post: 2nd Sep 2012, 09:49
