I want to cut out songs from DRM-removed itune movies and store them losslessly in copy mode to .ts files. the Media info output of the original file after removing drm is:
General
Complete name : G:\Stream\Asoka.mp4
Format : MPEG-4
Codec ID : M4V (M4V /mp42/isom)
File size : 6.02 GiB
Duration : 2 h 48 min
Overall bit rate : 5 107 kb/s
Movie name : Asoka
Performer : Santosh Sivan
Performer/Sorted by : Santosh Sivan
Director : Santosh Sivan
Actor : Shah Rukh Khan / Ajit Kumar / Kareena Kapoor / Danny Denzongpa / Rahul Dev / Hrishita Bhatt / Johnny Lever / Gerson Da Cunha / Subhashini Ali / Umesh Mehra
Screenplay by : Santosh Sivan / Saket Chaudhary
Producer : Shah Rukh Khan / Juhi Chawla
Production studio : Red Chillies Entertainments
Genre : Bollywood
ContentType : Unknown Type
Description : Prince Asoka (Shah Rukh Khan), the heir to the Province of mighty Magadha, bows to his mother (
Recorded date : UTC 2001-10-26 07:00:00
Encoded date : UTC 2016-06-06 20:39:37
Tagged date : UTC 2016-06-06 20:40:36
Cover : Yes
PurchaseDate : 2017-08-17 07:33:23
Title/Sort : Asoka
ContentRating : in-movies|UA|200|
LongDescription : Prince Asoka (Shahrukh Khan), heir to the Magadha Kingdom, bowing to his mother's (Shilpa Mehta) demand forsakes his princely status and goes to live in the wild for awhile. There he meets and falls in love with Kaurwaki (Kareena Kapoor). He identifies himself as Pawan, not wanting to disclose his identity yet. asoka has to return to Magadha, but when he returns to find and wed Kaurwaki, he is told by Bheema (Rahul Dev) that Kaurwaki and her brother Arya have been killed. Devastated asoka returns home. On the way home he is attacked and Devi (Hrishitaa Bhatt), of the Buddhist faith rescues him and tends to him till he gets well. As a result, Devi's marriage to her groom is cancelled. asoka weds her and brings her to Magadha, only to be told by his father that since Devi is not of the same race as he, she cannot be welcomed. asoka leaves with Devi and lives in Ujjaini. Soon Devi gets pregnant, and this arouses jealously and hatred amongst asoka's step-brothers. As a result they plot to kill Devi, however, their plans are foiled by asoka's mother, who is killed. Asoka swears to avenge his mother's death by killing his step-brothers one by one, except for one, who has led to Kalinga. asoka asks the ruler of Kalings to turn over his step-brother to him, and they refuse. asoka swears to raze Kalinga to the ground. asoka is unstoppable. Even his close friend, Virat (Danny Denzongpa), too, is unable to stop asoka. asoka proceeds to war, little knowing that the queen of Kalinga is none other than Kaurwaki, who is still alive.
Video #1
Format : AVC
Format profile : High@L4
Format settings, CABAC : Yes
Format settings, RefFrames : 5 frames
Codec ID : avc1
Bit rate : 4 589 kb/s
Width : 1 920 pixels
Height : 816 pixels
Display aspect ratio : 2.35:1
Frame rate mode : Constant
Frame rate : 25.000 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.117
Stream size : 5.41 GiB (90%)
Title : Core Media Video
Language : English
Color range : Limited
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Video #2
Format : JPEG
Codec ID : jpeg
Bit rate mode : Variable
Bit rate : 1 650 b/s
Width : 640 pixels
Height : 272 pixels
Display aspect ratio : 1.85:1
Frame rate mode : Variable
Frame rate : 0.001 FPS
Minimum frame rate : 0.000 FPS
Maximum frame rate : 0.014 FPS
Color space : YUV
Chroma subsampling : 4:4:4
Bit depth : 8 bits
Compression mode : Lossy
Bits/(Pixel*Frame) : 9.478
Stream size : 1.57 MiB (0%)
Default : No
Menu For : 2,8
Audio #1
Format : AAC
Format profile : LC
Codec ID : 40
Source duration : 2 h 48 min
Bit rate : 127 kb/s
Nominal bit rate : 160 kb/s
Maximum bit rate : 270 kb/s
Channel(s) : 2 channels
Sampling rate : 48.0 kHz
Frame rate : 46.875 FPS (1024 SPF)
Stream size : 153 MiB (2%)
Source stream size : 153 MiB (2%)
Title : Core Media Audio
Language : Hindi
Default : Yes
Alternate group : 1
Fallback From : 8
Menus : 6,7
Audio #2
Format : AC-3
Format/Info : Audio Coding 3
Format settings, Endianness : Big
Codec ID : ac-3
Bit rate mode : Constant
Bit rate : 384 kb/s
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Frame rate : 31.250 FPS (1536 SPF)
Bit depth : 16 bits
Stream size : 464 MiB (8%)
Language : Hindi
Service kind : Complete Main
Default : Inherited From: 2
Alternate group : 1
Fallback To : 2
Menus : 6,7
Text #1
Format : Timed Text
Muxing mode : sbtl
Codec ID : tx3g
Duration : 2 h 44 min
Bit rate : 79 b/s
Stream size : 95.5 KiB (0%)
Title : Core Media Subtitle
Language : English
Default : Yes
Forced : No
Alternate group : 2
Text #2
Format : Timed Text
Muxing mode : sbtl
Codec ID : tx3g
Duration : 2 h 45 min
Bit rate : 87 b/s
Stream size : 105 KiB (0%)
Language : German
Default : No
Forced : No
Alternate group : 2
Text #3
Format : Timed Text
Muxing mode : sbtl
Codec ID : tx3g
Bit rate : 73 b/s
Stream size : 88.3 KiB (0%)
Language : Malay
Default : No
Forced : No
Alternate group : 2
Menu
Codec ID : tx3g
Title : Core Media Text
Language : Hindi
Menu For : 2,8
00:00:00.000 : शीर्षक
00:01:13.720 : सन सनना... (गीत ०१)
00:25:04.560 : आ तैयार होजा... (गीत ०२)
00:43:15.800 : ओ रे कांची... (गीत ०३)
00:58:55.360 : रौशनी से... (गीत ०४)
01:34:54.720 : रात का नशा... (गीत ०५)
01:47:05.440 : अंत क्रेडिट
Bit rate mode : VBR
The problem is when i use Avidemux directly with this file output from drm remover software, it simply hangs so i need to copy(NOT re-encode)the original .mp4 file. to .ts format before using Avidemux for cutting the video.
Using ffmpeg in the following manner seems to convert the video and increase the bitrate as well: ffmpeg -i input.mp4 -vcodec copy -acodec copy -f mpegts output.ts.
I also tried ffmpeg -i input.mp4 -c copy -bsf h264_mp4toannexb output.ts. wththe same result
Can somebody suggest me how to losslessly change .mp4 to .ts so that i can use Avidemux for cutting .ts files in copy mode. Also if somebody can suggest a better video cutter for .ts files in copy mode( NO Re-Encoding required)
Transport streams naturally have more overhead than mp4 or mkv. There isn't really any way around the resulting bitrate increase.
Do you have any reason for choosing TS other than AviDemux hanging? You could try to report the problem to the AviDemux people. Or cut the mp4 with ffmpeg, or SolveigMM Video Splitter or VideoReDo. -
Hi sneaker, i want to keep all the output files in .ts form only as the bulk of the movies from streaming services are in .ts form. i use .m2ts for my bluray rips and .ts for streaming rips for my convenience.. Since the apple itunes movies can ONLY be converted to .mp4 losslessly during drm removal stage, i have to convert all the itunes movies from .mp4 to .ts so that my collection consists only of .ts files for convenience.
MKV to MP4 container
By Brian7k in forum MacReplies: 7Last Post: 17th Jan 2015, 22:49 -
HEVC video CUT with direct-stream-copy was successful with XMEDIA recode!
By Stears555 in forum Video ConversionReplies: 10Last Post: 6th Aug 2014, 09:42 -
How to cut MP4 video Files?
By OrtegaSeason in forum Video ConversionReplies: 2Last Post: 8th Dec 2013, 10:04 -
convert h264 avi container to mp4 container
By azukich in forum Video ConversionReplies: 0Last Post: 6th Apr 2013, 17:09 -
cut video and save as direct stream copy
By supercain in forum EditingReplies: 47Last Post: 8th Sep 2012, 10:32
