Does the Hauppauge Capture Software only let you trim the beginning and end or can you snip out a glitchy portion in the middle? The YouTube video made it sound like you can only trim the beginning and end.
What's a good software to trim or snip out a middle segment from a mp4 or ts? Thanks.
Most software lets you either KEEP what you select, or CUT what you select.
When you "select" something, you set(or select) a beginning and an ending(starting frame, ending frame) of what you want to cut/remove.
I think you are misunderstanding what the instructional video is saying. -
I've used software to edit videos before, so I know how they are supposed to allow you to define segments to keep or cut.
In Hauppauge Capture, a few things seem screwy. In the Edit tab, most of the time, the Cut and Split buttons are nowhere to be found. A video recorded via standalone mode copied to the harddrive's folder for Rocket videos are not detected, and no files at all can be Added since none are visible when browsing in folders where there should be video files. When I Play a video in the Edit tab, the Cut and Split buttons disappear. -
Does Smart Cutter always make weird blocky gray transitions at cut/edit points? Is the pay version cleaner?
Is there something that would make clean seamless edits?
Hauppauge PVR2 - audio sync issue with Hauppauge Capture -- alternative?
By texas1 in forum Capturing and VCRReplies: 35Last Post: 2nd Apr 2017, 02:27 -
Screen Capture Software for editing
By jbandy1 in forum Newbie / General discussionsReplies: 27Last Post: 20th Feb 2016, 04:53 -
Hauppauge 1512 Capture: .TS Files Won't Load Into Most Editing Apps
By johnmeyer in forum Capturing and VCRReplies: 59Last Post: 10th Feb 2016, 12:06 -
Hauppauge HD PVR 2 video freezes in capture software
By Yankee_In_TX in forum Capturing and VCRReplies: 3Last Post: 18th Oct 2014, 20:22 -
Capture Software for Hauppauge HD-PVR
By DarrellS in forum Capturing and VCRReplies: 41Last Post: 26th May 2013, 19:24
