I really miss XP, everything worked better on it. I need a video editor, a freeware, to extract clips from various formats of video and assemble them, and images, into a new video. With a new audio file. I don't need to add exotic effects, make new CGI animations, plot out brain surgery, learn an alien language as far as a menu, etc. Or load a new OS. Does such a thing exist? It's rather important. I'd hate to have to hunt up an XP computer on Ebay and blow two or three hundred just to do this. I absolutely would if I had it to spend.
I just need to make video clips, from various formats, for starters. A separate software to assemble them and add the audio track is fine.
Thanks for your time, and, hopefully, for your help. I have looked, and tried several that hang up on Windows 7, have tortuous, counter-intuitive mind-bending interfaces with graphs and color wheels that I will never have need of, and the instructions are no real help. I would use VLC, but the clips have no sound.
What did you use on XP that worked OK for you -- but doesn't work on Windows 7 or 10 ?
If this is a one time project and you can do it in less than a couple of weeks, why not just use the free trial of any version of Vegas or even Premiere Pro?
Load up your full clips. Mark ins and outs. Subbclip if you like. Assemble. Output. -
Hi
Why not "Avidemux"? Free, simple* & easy, autonomous: no codecs to install, & portable (just rename "avidemux.exe" to "avidemux_portable.exe").
Or "VirtualDub", also free and easy, but equipped with "FFInputDriver.vdplugin" (in "plugins32" subfolder) so that it will open almost all videos; knowing that it outputs to ".avi" container only — or to ".mp4", but complex to set...
______________
"2 or 300 bucks to buy an XP machine"?!
Instead, do the trash! — though it usually requires living in a city or town. Or garage sales. An XP box should never cost more than $50.
I'm using both Win. XP and 10 in such machines: found... in the streets. Main problem, with XP old central units: recoding — to AVC H.264 (x264) in "veryslow" mode anyway — takes for ever; while a basic 2013 "i3" laptop recodes between 4 and 6 times faster (than 2005~2008 "Pentium 4" CPUs).
Win. Vista and 8.x interfaces are hardly usable. So is Win. 7 IMHO and despite the fact it's SUPPOSED to be "the best"; I just don't agree: Win. 7 interface is ALSO a hassle.
Now, Win. 10 interface happens to be usable again — BUT: once the whole OS optimized... to the bone
= at least one long day if not more, of geek work, to rid it of a BUNCH of useless stuff, i.e. most auto. updates / upgrading, "Cortana" + unusable "full row select" craps, ETC. (I mean: MANY more)!
______________
______________
[ edit ] * Simple, here, means — mainly: no "timeline", and note, neither "crossfade" effect; but fade-to-black in/out OK**.
By defaut, "Avidemux" is set to "Copy" (on both video & audio streams) = no recoding = no quality loss, but cuts allowed ON key frames only, labelled "I (intra-frame)" at bottom, when found. Double triangle blue buttons will jump to key frames.
To cut BETWEEN key frames, at least select one of the top left Video section codecs; Audio can stay in Copy mode, or a codec can be selected as well.
** Fade-to-black filter: whatever you see, just assume "hours: mn: sec: milliseconds": in THAT order (& no other), or check:
.Last edited by bulgom; 4th Sep 2017 at 18:17.
Video Converters that supports most video formats, RM, FLV, WMV, MOV, MP4
By Baldrick in forum Video ConversionReplies: 134Last Post: 31st Mar 2021, 11:27 -
recommend simple video screen capture (freeware)
By sportflyer in forum Video Streaming DownloadingReplies: 1Last Post: 10th Oct 2015, 12:55 -
Editing 1080p and 720p video clips into one video
By robbyrob in forum EditingReplies: 16Last Post: 16th Jul 2015, 10:04 -
Freeware that plays video backwards?
By Shikkyn in forum EditingReplies: 15Last Post: 12th May 2015, 08:17 -
Extract video files from a iso Like dvdfab does... Freeware
By RBCC in forum DVD RippingReplies: 4Last Post: 2nd May 2013, 22:39
) — see attachment:
