But I'm pretty sure that you get a message about a missing msvr210.dll (or similar) when that's the problem though.
Results 61 to 68 of 68
I would not bet on that. If an application cannot be executed due to missing design-time linked DLL's, a specific error message is usually available out of the application's process. But if a DLL (AviSynth) cannot load a run-time linked (plugin) DLL, the communication is much more indirect, there may not be more information available than "cannot load a DLL" (error=0xc1) to the hosting process, and that may happen for an unsupported bitness as well as for unavailable runtime DLL's.
Specifically, I don't know how verbose AviSynth (legacy or plus) can report the reason, according to the plugin API, I am no plugin programmer... -
Hello @jagabo & @manono
I've used your script :
LwLibavVideoSource("Telecine.mkv")
TDecimate()
for years now to convert web-dl (29,97 fps progressive to 23.976 fps progressive) and it's worked perfectly until I cross this clip, after there seems to be some interlace artifacts left in the video, I'm not too sure what to do to give it the good process and fluidity as it should be.
I'm uploaded 2 clips (original and after the process)
Thanks for your help guys -
It's badly deinterlace SD, upscaled to 1080p. This will detect most of the combed frames and replace them with the previous frame:
It may miss a few here and there. And it may sometimes misidentify real picture content as combing. Note that the title sequence was originally 30i but was deinterlaced to 30p. If you decimate that to 24p it will get jerky.Code:LWLibavVideoSource("Les Invincilbles - Episode 1 (original).mkv") testclip = Spline36Resize(640,360) decombed = Loop(2,0,0) ConditionalFilter(testclip, decombed, last, "IsCombedTIVTC") TDecimate() -
Thanks for the reply,
I'm testing this script and can't load this in VirtualDub at the line : ConditionalFilter(testclip, decombed, last, "IsCombedTIVTC")
Do I need a new .dll or a condition to "IsCombedTIVTC" ?
Thanks -
IsCombedTTIVTC is included in the TIVTC package:
http://avisynth.nl/index.php/TIVTC
Converting MP4 to MPG/VOB (Progressive to Interlaced)
By danielmak in forum MacReplies: 7Last Post: 7th Oct 2016, 07:58 -
Is mp4/mpeg4 designed for progressive rather than interlaced?
By SyncroScales in forum Video ConversionReplies: 7Last Post: 22nd Jul 2015, 07:42 -
Ho to get a pure interlaced mp4 with ffmpeg?
By marcorocchini in forum Newbie / General discussionsReplies: 113Last Post: 27th Nov 2014, 18:25 -
Ripbot264 tutorial for Interlaced VC1 to Roku mp4?
By WBFAir in forum Blu-ray RippingReplies: 4Last Post: 16th Aug 2013, 07:47 -
Interlaced .mp4, can't deinterlace.
By nick101181 in forum Newbie / General discussionsReplies: 7Last Post: 21st Oct 2012, 17:21
