Hi,
quick question, if I have two copies of the same movie in MKV, both in a different language, and want to add the audio track from one, to the other using mkvmerge, will mkvmerge keep the tracks settings/properties from the original file (like audio delay, fps + whatever else may have been manually set) or do I have to re-enter them? I understand that the newly added track may not be in sync with the video, but that's fine as I can adjust it after. I just wanna make sure that the MKV movie to which I'm adding the new audio track remains untouched apart from that new track.
thanks
Track name, timings (result from delay and fps), aspect ratio, language will be kept. But for example if you have 2 audio tracks in 2 mkv files were both are default track only one of them will be default after merging. Some more technical details may be changed e.g. mkv compression (header removal, zlib, ...) will be reset to mkvmerge default (I doubt that will be important to you).
Ah that's perfect, thanks a lot buddy!!
Last thing, I assume I have to add the main MKV first right ? or does the order in which the tracks are added not matter ?
Replacing thumbnail on .mkv file using mkvtoolnix or mkvmerge
By PeterProg in forum Newbie / General discussionsReplies: 17Last Post: 7th Mar 2017, 00:56 -
Add subtile (srt) file to existing mkv file
By Hansen in forum SubtitleReplies: 6Last Post: 4th Dec 2016, 04:58 -
Invisible Audio/Video Tracks in MKVMerge
By ConverterCrazy in forum Latest Video NewsReplies: 8Last Post: 8th Aug 2015, 15:17 -
Burn MKV file with audio tracks to DVD on Mac
By crissrudd4554 in forum MacReplies: 21Last Post: 21st Mar 2015, 01:09 -
MKVMerge - Removing 'Tags for tracks'
By THRobinson in forum EditingReplies: 11Last Post: 21st Feb 2015, 14:25
