I recently upgraded from Avid Studio to Pinnacle 21 Plus. The interface is very similar and I have been able to create a disk project somewhat easily. When I export the movie to a blu ray disk, the software creates an image for the entire movie (I can see the disk menu and all the chapters play). However, after the disk is done and I play it, the disk menu does not display and only the last chapter plays (automatically). How do I get the disk menu to work?
I am also confused by the project size. On the Export screen the Estimated Project Size is 30.72. But, the Used Space bar only indicates 50% used. Is the project too large for a 25 GB blu ray disk? Or, am I interpreting this information incorrectly? If yes, what, if anything, can I do to compress the clips so they will fit on the disk?
For projects I created in Avid Studio, I would create and image and burn the image. In Pinnacle, when I attempt to burn the image, I am prompted to locate the image file. I cannot find an "image" file. I have created a separate folder for the image file to help locate it. There are several files placed in this folder when I create an image. How do you know what file to select when you burn the image?
Thanks, in advance, for your assistance.
srd
Results 1 to 1 of 1
Home movies put on DVD, incl. menu, now on NAS. How to display menu on TV?
By zigjam1 in forum Newbie / General discussionsReplies: 7Last Post: 30th Dec 2016, 16:51 -
Force display the top menu at startup with BDEdit
By sglitch in forum Authoring (Blu-ray)Replies: 0Last Post: 9th May 2014, 17:50 -
Software to read a DVD disk and convert it to a Blu-Ray disk
By andy jackson in forum Newbie / General discussionsReplies: 5Last Post: 11th Nov 2013, 19:32 -
DVD player locks up when I try to play disk with menu authored by DVD Flick
By aprete in forum Authoring (DVD)Replies: 2Last Post: 19th Jun 2013, 21:19 -
wlmm - video clips display do not display correctly?
By OleMan in forum EditingReplies: 7Last Post: 12th May 2013, 10:32
