Results 1 to 17 of 17
  1. When converting a dfxp file to srt, I run into the following problem:
    Line breaks aren't converted by Subtitle Edit and some other programs. The resulting file is therefore in 1 line and missing some spaces. Likein thisexample.
    The dfxp file does contain a tag to break, namely: <tt:br/>
    But this doesn't work and is ignored.
    I have a workaround but it's not a solution.
    Any ideas for alternatives?
    This is nøt å signåture.™
  2. Originally Posted by roma_turok View Post
    Do you have short dfxp file sample?
    Certainly:
  3. Try to replace <tt:br/> with <br />
  4. Originally Posted by videobruger View Post
    That was the first thing that I tried but it makes the dfxp file unreadable for Subtitle Edit.
  5. Hi.
    See if the file is OK.
  6. That was the first thing that I tried but it makes the dfxp file unreadable for Subtitle Edit.
    Not here. Subtitle Edit 3.5.3
  7. Originally Posted by roma_turok View Post
    You can convert dfxp file to srt on this site: https://gotranscript.com/subtitle-converter
    Tried that, same error.
  8. Originally Posted by devilcoelhodog View Post
    Hi.
    That one is OK. I had a workaround myself, it's just that it requires some extra work that might be avoided.
  9. Originally Posted by videobruger View Post
    [Attachment 42983 - Click to enlarge]
    But subtitle edit can't find "<tt:br/>"?
  10. Open the Angel 1984 4511552a-0368-4ed6-bc79-7c6bae7e312f.dfxp in a text editor.
    Replace <tt:br/> with <br /> and save.
    Drop the file onto Subtitle Editor.
  11. Hi, dear all.
    I did just like videobruge said. After that, using Notepad, I have saved the file and opened it using Subtitle Edit ( portable / latest version ).
    Then, I saved the file into srt format. No problems concerning line break / space.
    Can you do it without any issues now?
  12. I guess I forgot the space inside that tag, because br/ doesn't work but br / does. Thanks, that's at least an easier workaround than what I used before.
  13. Member Kameleon's Avatar
    Oct 2017
    Belgium
    Hi, is there a TimedText specification document of the dfxp format where the 'tt:' addition is present?
    In all specifications I've seen I can not find it, and I would like to be sure before I implement it in Subtitle Workshop...
    Thanks in advance!
    Kind Regards,
    Kameleon
    Aug 2010
    San Francisco, California
    That looks like a default prefix from the W3C candidate recommendation. The root tt element could have any prefix, or none, defined for the http://www.w3.org/ns/ttml namespace.
  15. Member Kameleon's Avatar
    Oct 2017
    Belgium
    Clear. Thanks!
    Kind Regards,
    Kameleon
