  1. Is it possible to attach scroll to change window size in MPC-HC instead of changing volume?
  2. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    Here is the full list of hotkeys: http://shortcuts-keys.blogspot.com/2016/03/media-player-classic-shortcuts.html
    As noted at the top of the page, I believe they can be remapped in the location noted.
    I don't have it installed on this PC to test.
    Google is your Friend
  3. Originally Posted by Krispy Kritter View Post
    Here is the full list of hotkeys.
    All i found is to change video size inside the window
  4. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    Sorry, forgot to add the url.
