  1. Hello,
    few months back I have been using As Video Converter and it was working great. But now it does not work at all no matter what settings I choose or what type of video file I throw in it it always fail. I am not sure what could have happened in the past few months but even the old version that did work past then, does not work right now.
    By the way here is the log from this app, maybe it will help. There is something with the splitter at the end...
  2. Member DB83's Avatar
    Jul 2007
    Just a guess.
    Did you by chance install the recent version ?
    Notes state that previous version MUST be uninstalled before the install.
    So suggest you uninstall any version(s) in your system and re-install.
  3. Originally Posted by DB83 View Post
    Just a guess.
    Did that already without success
  4. Member DB83's Avatar
    Jul 2007
    Well if that is the case (the impression I had was that you had more than one version in your system since you referred to the old version) then all you can do is think what changes you have made to your system in the mean time.
    And since it's a free program you have not exactly lost anything. Nearly all these free (and commercial for that matter) conversion programs are little more than a front-end to ffmeg so you can always try another one. Plenty of choice in the software section on this site.
