Hi All!
First post here. I have an opportunity to buy a Marantz MV5100 (w/o remote). My intention is to use this to convert old home VHS tapes to digital for uploading to youtube for the family to view. Based on my research, it seems a VHS player with built in TBC is going to be my best option.
I want to know if this VHS player has this. I have found some info that it is a re-badge of a JVC 9000 series (which I understand is a pretty awesome unit with TBC), but have not been able to corroborate this.
Any info would be much appreciated. Thanks all!
I wouldn't worry so much about the built in TBC on any VCR you are looking at, chances are it will give you a better quality image overall but It won't likely be enough to give you a stable digital conversion through any sort of capture device. Obviously don't use that as a reason to not buy a good VCR this just means you will have to pass the signal through a Panasonic DMR-ES series DVD recorder or full frame TBC like a TBC-1000.
So regardless of what VCR you have you will need an external TBC of some sort, choosing a higher quality VCR will only result in differing features and potentially video quality / stability.
Archiving old VHS footage to digital. Home deck or computer?
By Gil T Remnant in forum RestorationReplies: 4Last Post: 8th Aug 2016, 18:35 -
Home Movie Conversion
By mkd8919 in forum Capturing and VCRReplies: 12Last Post: 7th Apr 2016, 03:01 -
Professional Sony VCR SVP-5600 TBC Question
By ecksmedia in forum Capturing and VCRReplies: 4Last Post: 2nd Apr 2015, 15:24 -
What is a good TBC analog - digital converter box for hi-8 tape conversion?
By timecapture in forum Capturing and VCRReplies: 2Last Post: 10th Sep 2014, 19:28 -
Digitizing from Hi-8 - how to incorporate TBC question
By John BKNY in forum RestorationReplies: 2Last Post: 9th Jan 2013, 06:02
