hello all, im in the process of cleaning some vhs captures, i have alot of grain/noise on some of them .... i have purchased neat video plugin for vegas 14 would this be a good option for cleaning the video ...![]()
Results 1 to 10 of 10
Just don't overdo it. A common mistake with beginners is they concentrate on removing all the noise -- and don't notice that also lost all the image detail. Fuzzy sweaters look like silk jackets, subtle wood grain disappears, people look like mannequins, etc.
+1 Jagabo.
I've posted that same thing 100+ times in the past ten years. The famous mantra "less is more" most definitely applies.
People are so happy to see the noise disappear that they often don't realize how many other things are disappearing as well. -
+1 Jagabo
Very true. I do a compare multiple times just to make sure there is a minimal loss of detail.
And be prepared for long render times, too. -
you can use neat in avisynth and should give you better results than vdub+neat imo (as far respect to the interlacing and chroma subsampling precision at least). the thing is you have to use vdub first to make the noise profile.
example (read neat's doc for more infos)
ConvertToRGB32(matrix="Rec601",interlaced=true)
LoadVirtualDubPlugin("C:\Program Files (x86)\VirtualDub\plugins\NeatVideo.vdf", "NeatVideo", 2) # Neatvideo version 3(gpu)
NeatVideo("C:\Program Files (x86)\Neat Video for VirtualDub\PROFILES\myprofile.dnp", "C:\Program Files (x86)\Neat Video for VirtualDub\PRESETS\my profile.nfp", "1.0", "2", "1", "1" )
convertyoyv12(interlaced=true)*** DIGITIZING VHS / ANALOG VIDEOS SINCE 2001**** GEAR: JVC HR-S7700MS, TOSHIBA V733EF AND MORE
Neat Video
By timsky in forum RestorationReplies: 2Last Post: 11th Aug 2016, 19:11 -
Does Neat Video have issues with HuffYuv codec?
By brassplyer in forum EditingReplies: 3Last Post: 4th Jan 2015, 17:58 -
VirtualDub Neat Video scan type question
By kodec in forum RestorationReplies: 2Last Post: 1st Nov 2014, 07:12 -
Neat Video
By july76 in forum RestorationReplies: 0Last Post: 20th Jan 2013, 05:12 -
New to Neat Video and Need Help
By VideoFanatic in forum RestorationReplies: 5Last Post: 26th Aug 2012, 12:12
