Hello all, if you want to watch the movie or TV show you bought from iTunes store on your Android phone, or other non-Apple devices, you need to removal the DRM Protection first. The following will show how to remove the DRM protection with DVDFab DRM Removal for Apple.
Note: Before using DVDFab DRM Removal for Apple, you need to allow iTunes to “share iTunes library XML with other applications”. Please run iTunes, navigate to Edit > Preferences > Advanced, and check the box before “Share iTunes Library XML with other applications”. Moreover, you have to make sure your iTunes is logged in.
Step 1 > Run DVDFab 10, go to Utilities module, and click DRM Removal for Apple. Then there will be two options for you, and please choose “For Video”.
[Attachment 42912 - Click to enlarge]
Step 2 > Add iTunes video file. You can click “Add from Windows” to add the file from This PC > Music > iTunes > iTunes Media (the default folder location of iTunes), or click “Add from iTunes” to add the file directly from iTunes, or drag the file to main interface to add it.
[Attachment 42910 - Click to enlarge]
Step 3 > Click the “folder” icon to select a directory to save the output video. And then you can click the “Start” button to begin the process of removing DRM.
[Attachment 42911 - Click to enlarge]
After the process is done, you can check the output video, which is already drm-free, and can be palyback on various devices.
For more information of this DRM Removal tool,you can visit its page: https://www.dvdfab.cn/drm-removal.htm
Closed Thread
The technique of removing the DRM protection from the iTunes videos is really good to see. If you are trying to do this and failed then at first you need to check whether you updated your system software or not. Because without the software update you can’t install iTunes on Windows 10 so you need to be very careful about that. And the main thing if the software update properly installed then check the iTunes twice.
Apparently it's a Windows application judging from the screenshot.
It should be able to maintain the original quality.
An analogy about how Apple's DRM protection works:
(highly inaccurate but comparable)
Storing the original file (decodable by standard decoders) in a password protected RAR, with the password generated based on the user information.
Remove DRM protection from f4v videos!??
By matths in forum Video Streaming DownloadingReplies: 4Last Post: 22nd Mar 2015, 12:57 -
Remove DRM form iTunes M4V Movie
By wildsharks in forum Video ConversionReplies: 2Last Post: 6th May 2014, 06:54 -
Quick Question about removing the DRM from iTunes videos
By R&MFan in forum Video Streaming DownloadingReplies: 11Last Post: 21st Apr 2013, 23:28 -
How to remove DRM from iPlayer videos?
By VideoFanatic in forum Video ConversionReplies: 2Last Post: 3rd Jan 2013, 06:43 -
DRM Removal Program to Remove iTunes DRM Protection
By Teac23 in forum AudioReplies: 1Last Post: 17th Dec 2012, 08:26
