Results 1 to 12 of 12
    Jul 2017
    Spain
    As title says, I'm having problems encoding files through latest XMedia with the same configuration as VidCoder, which works perfectly for my TV USB native player but doesn't allow me to burn-in .ass subtitles (which are necessary for 3D viewing). XMedia gives me the "unsupported video codec" message on TV, as well as the error (little X) thumbnail.
    Does anyone know which settings should I accomodate in XMedia Recode so I can replicate the functioning VidCoder encoding?
    Here is the MediaInfo of a VidCoder-encoded perfectly playable file:
    Format : Matroska
    Format version : Version 4 / Version 2
    File size : 8.75 GiB
    Duration : 1 h 30 min
    Overall bit rate : 13.8 Mb/s
    Encoded date : UTC 2017-08-17T18:32:32Z
    Writing application : HandBrake 1.0.7 2017040900
    Writing library : Lavf57.7.2 / Lavf57.7.2
    Video
    Format : AVC
    Format profile : Main@L4
    Format settings, CABAC : Yes
    Format settings, ReFrames : 4 frames
    Codec ID : V_MPEG4/ISO/AVC
    Nominal bit rate : 13.5 Mb/s
    Width : 1 920 pixels
    Height : 1 040 pixels
    Display aspect ratio : 1.85:1
    Frame rate mode : Constant
    Frame rate : 23.976 (24000/1001) FPS
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.282
    Writing library : x264 core 148 r2708 86b7198
    Encoding settings : cabac=1 / ref=1 / deblock=1:0:0 / analyse=0x1:0x111 / me=hex / subme=2 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=0 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=0 / threads=6 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=1 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=10 / rc=2pass / mbtree=1 / bitrate=13511 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=20000 / vbv_bufsize=25000 / nal_hrd=none / filler=0 / ip_ratio=1.40 / aq=1:1.00
    Default : Yes
    Forced : No
    Color range : Limited
    Color primaries : BT.709
    Transfer characteristics : BT.709
    Matrix coefficients : BT.709
  2. MediaInfo of your XMedia Recode file? (Complete, incl. info about sound, subtitles...)
  3. Also give the model of the LG TV.
    Jul 2017
    Spain
    The model is LG 42LW4500
    Here's the offending MediaInfo from a snippet I've made with the same results:
    Format : Matroska
    File size : 314 MiB
    Duration : 4 min 39 s
    Overall bit rate : 9 442 kb/s
    Encoded date : UTC 2017-08-22 23:33:10
    Writing application : Lavf57.57.100
    Writing library : Lavf57.57.100 / Lavf57.57.100
    ErrorDetectionType : Per level 1
    Video
    Format : AVC
    Format profile : Baseline@L4.1
    Format settings, CABAC : No
    Format settings, ReFrames : 5 frames
    Duration : 4 min 38 s
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Color space : YUV
    Bit depth : 8 bits
    Writing library : x264 core 148 r2721
    Encoding settings : cabac=0 / ref=5 / deblock=1:0:0 / analyse=0x1:0 / me=umh / subme=8 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=0 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=6 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=0 / weightp=0 / keyint=239 / keyint_min=23 / scenecut=0 / intra_refresh=0 / rc_lookahead=50 / rc=crf / mbtree=0 / crf=18.0 / qcomp=0.60 / qpmin=10 / qpmax=69 / qpstep=4 / vbv_maxrate=9500 / vbv_bufsize=24000 / crf_max=0.0 / nal_hrd=none / filler=0 / frame-packing=4 / ip_ratio=1.40 / aq=0
    Language : English
    Default : Yes
    Forced : No
    DURATION : 00:04:39.008000000
    Audio
    Format : AAC
    Format profile : LC
    Codec ID : A_AAC
    Channel(s) : 2 channels
    Sampling rate : 48.0 kHz
    Frame rate : 46.875 FPS (1024 spf)
    Compression mode : Lossy
    Delay relative to video : -21 ms
    Writing library : Lavc57.66.101 aac
    Language : English
    Default : No
    Forced : No
    Please note that if I make an Ultra-fast conversion (this is Slow) the file works perfectly.
  5. Use High Profile level 4.0. Do not use more than 4 ref frames for 1920x1080.
    Jul 2017
    Spain
    How do I change the ref frames? I can't find the option
  7. Extra > Number of Reference Frames
    Jul 2017
    Spain
    Okay, thank you! This seems to work.
    Now, even with Slow profile it seems that there's some blocking on fade-ins and fade-outs (image to black and backwards). What's the best Constant Quality value to keep the file as closer to the original? Don't care about size.
    Oh, and if this isn't too much to ask, how can I save a profile on XMedia? When I click the star icon I can only pick existing profiles to add them on Favorites list.
  9. The lower the value the better the quality. 18 is usually perceived as good. 16 is borderline overkill. You have to experiment a bit yourself.
    Can you show the MediaInfo of your current result? Maybe someone can give additional tips about improving fades, then.
    Jul 2017
    Spain
    Sure,
    Format : Matroska
    File size : 389 MiB
    Duration : 6 min 12 s
    Overall bit rate : 8 759 kb/s
    Encoded date : UTC 2017-08-23 13:14:35
    Video
    Format : AVC
    Format profile : Baseline@L4 (It says Baseline@L4, shouldn't it say High@L4? That's what I selected in XMedia)
    Color space : YUV
    Bit depth : 8 bits
    Encoding settings : cabac=0 / ref=4 / deblock=1:0:0 / analyse=0x1:0 / me=umh / subme=8 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=0 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=6 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=0 / weightp=0 / keyint=239 / keyint_min=23 / scenecut=0 / intra_refresh=0 / rc_lookahead=50 / rc=crf / mbtree=1 / crf=18.0 / qcomp=0.60 / qpmin=10 / qpmax=69 / qpstep=4 / vbv_maxrate=9500 / vbv_bufsize=24000 / crf_max=0.0 / nal_hrd=none / filler=0 / frame-packing=4 / ip_ratio=1.40 / aq=1:0.00
    Language : English
    Default : Yes
    Forced : No
    DURATION : 00:06:12.268000000
    Audio
    Format : AAC
    Format profile : LC
    Codec ID : A_AAC
    Language : English
    Default : No
    Forced : No
    DURATION : 00:06:12.258000000
  11. Originally Posted by slit View Post
    You have CABAC and bframes turned off. I suggest you hit "Reset" and then set profile, preset, level and quality again. Then check CABAC, bframes and ref frames settings for correctness.
    Your maxrate is kinda low. You can set vbv maxrate and vbv bufsize to 20000. qpmin 1. For high quality encodes tune grain can be useful (but not always). AQ mode 3 is biased for darker scenes. Maybe you want to try it.
    Jul 2017
    Spain
    Wow, so much info Okay, time to read about some obscure terms. Thanks for your help sneaker
