On retail DVD's, you can only read but not write, They are always full to capacity.
I'm burning a home movie ISO (2gb) to a dvd (4gb), And I can always still add files to the DVD after the burning, does my ISO have to be 4GB.
AnonymousGuest
No, they're not.
No....does my ISO have to be 4GB.
Either that's incorrect or your DVDs aren't being finalized. Use ImgBurn to burn to disk.I'm burning a home movie ISO (2gb) to a dvd (4gb), And I can always still add files to the DVD after the burning... -
Provided you are not using rewritable discs and you finalize them, nothing more can be written to them, even if there is remaining space.
There are applications which allow more to be added to rewritable discs, they read the original contents, erase the disc then write it back with the added files so it all takes place in one write session. You can't do that on normal DVD+R or DVD-R discs though, only rewritable ones.
Brian. -
The scenario described above can be done manually, without any special software. I have done so many times. Re-writable DVD media is designed to be erased and re-used.
However, creating actual multi-session discs, which can be done with a program like CDBurnerXP or Nero using write-once DVD media, is discouraged by most members here because reading such discs is often problematic, especially using a different PC. That is because multi-session discs are left open (not finalized) after each session.Last edited by usually_quiet; 21st Aug 2017 at 16:36.
Can't read DVD data disc on XP
By AlanHK in forum ComputerReplies: 3Last Post: 4th Sep 2015, 23:05 -
How i make my ( LG 42" LED 3D 42LA6130 ) read more than one subtitle ?
By ALAA ELDIN in forum SubtitleReplies: 14Last Post: 7th Apr 2014, 09:41 -
Panasonic dmr es15 wont read any divx or dvd on dvd rw-+
By mammo1789 in forum DVD & Blu-ray RecordersReplies: 9Last Post: 20th Oct 2012, 08:52 -
Make RipBot264 read alot of m2ts to create one file
By Cazz in forum Blu-ray RippingReplies: 2Last Post: 2nd Oct 2012, 14:39 -
dvd read error
By jeffcool in forum Video ConversionReplies: 1Last Post: 24th Aug 2012, 14:31
