Hi to everyone.I have a problem with an AVI file.I was recording a game for my pc with bandicam with this settings:
Codec:RGB24
Bitrate:4000kbps
Quality:90
When I was recording the game was running pretty fine.The problem is that when i open the avi file ,that I've recorded, it lags.
I tried to record with different settings,and If i set a different Codec the avi file donesn't lag.But i need the previous video,how I should fix it?
Results 1 to 12 of 12
It looks like you captured uncompressed video using the RGB24 colorspace. Uncompressed means no codec (compression) was used. The MediaInfo report shows the actual bitrate, 175 Mbps (175000 kbps). If you look at your capture settings, bitrate and quality settings are unavailable.
I don't know how to fix your existing file, but I can guess what the problem is. Capturing uncompressed HD video successfully requires HDDs in a raid array or an SSD. There were probably a lot of dropped frames in your capture, which would cause the video and audio to loose synchronization.Ignore list: hello_hello, tried, TechLord, Snoopy329 -
Your hard drive isn't fast enough to store uncompressed RGB at the resolution your running at (>300 MB/s). Use a fast lossless compression codec like UT Video Codec. That will compress the video enough for the hard drive to handle. Or record at a lower resolution and/or frame rate.
Uncompressed RGB24 would be >300MBytes per second at the given resolution and fps. But weirdly, OP's media info is reporting 175Mbits per second which is like ~20MBytes per second. Anyway Bandicam does support external VFW codecs like ones used in Virtualdub, like UT Video for RGB as already mentioned.
https://www.bandicam.com/faqs/vfw-x264-xvid-divx-h264-codec/ -
Aaaaaand i can't fix that.Well,i will try a different soultion.Thanks to all of you!
Avi with Indeo Codec
By Bala Arizalu in forum Video ConversionReplies: 8Last Post: 4th Jul 2016, 09:52 -
AVI to AVI with different video codec?
By coasttocoast in forum Video ConversionReplies: 5Last Post: 29th Jun 2016, 18:23 -
What Codec Do I Need to Play This AVI?
By SameSelf in forum Video ConversionReplies: 21Last Post: 30th Jan 2016, 17:37 -
AVI video codec
By moera in forum Newbie / General discussionsReplies: 4Last Post: 28th Jan 2016, 08:58 -
being trying to convert avi to another avi codec
By ang3lus in forum Video ConversionReplies: 8Last Post: 25th Apr 2013, 16:07
