hello i have a 8mm film scanner - winait - and i have been capturing some footage from cine reels and happy with the quality but when i play the files back the motion seems faster than it should be :/ .... i have encoded them to 25fps from 30fps with not much joy in the playback speed .... can anyone help please![]()
Results 1 to 12 of 12
8 mm film is 18 fps silent, 24 fps with sound. So encoding the scan to 30 fps will show speed-up. (If you ever watched the silent newsreels you often experienced that effect).
I think the solution is to take the original scan - assume @18 fps - and duplicate every 6th frame. So you now have 24 fps. If you still require NTSC 30 fps you then apply pulldown to that. -
Super 8 mm is usually 18 fps but Standard 8 mm is most often 16 fps. Cameras have lower rates and sometimes people used them to save film. I scanned a lot of Standard 8 that was 12 fps.
If you are watching these scans on a modern digital device there is probably no reason to mess with pulldown and duplication. Just encode it to the correct frame rate. -
What kind of files come out of your Winait? Do you have access to the individual frames as a sequence of image files?
FFmpeg is a wonderful tool for those who overcome fear of the command line.
The number after the -r option is the desired new framerate in frames-per-second. This technique avoids re-encoding and preserves quality.Code:ffmpeg -r 18 -i myinput.mp4 -c copy myoutput.mp4
Sony handycam doesnt auto switch over from digital 8 to 8mm playback
By Sir_Loin in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 26th Jun 2017, 03:58 -
The Rokinon 50 and 85 cine lenses
By newpball in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 12th Jul 2015, 16:03 -
Playback 8x speed - can't do it.
By caipirovisk in forum Newbie / General discussionsReplies: 2Last Post: 11th Feb 2014, 19:41 -
Pixelated Edge on Digital 8mm Playback. Please Help
By bradfordly in forum Newbie / General discussionsReplies: 3Last Post: 31st Dec 2013, 09:22 -
DVDRemakePro 3.6.3 - How to fix end of playback to go back to the menu?
By DwightFry78 in forum DVD RippingReplies: 11Last Post: 22nd Dec 2012, 11:23
