I am trying desperately to sync 2 audio language files and the related video. The video comes only with italian language audio but I had a version in my language in horrible quality on VHS. I have ripped the audio from that VHS but I cannot succeed in getting both audio files in sync.
Is there any tool that could help me with this job ?
Thanks !
Yes, I tried the same with Wavelab but without success after hours...
I was hoping for a tool that allows me to switch back and forth between both languages while showing the video and that would allow me to set stretch-markers or something similar... -
Open the video in VirtualDub FilterMod and select 'save WAV' from the File drop down menu.
If necessary, convert the ripped audio file from your VHS to the same WAV format. You can then open both files in Audacity multitrack mode and see both audio files together. Edit the VHS file to match the wav file from the video. As you will be able to see both complete audio files next to each other, it should makeit easier to match them.
Lots of mp4 videos with wrong language metadata, bulk tool to fix?
By wkearney99 in forum Newbie / General discussionsReplies: 13Last Post: 22nd May 2017, 07:37 -
Syncing an audio track
By carlmart in forum AudioReplies: 10Last Post: 4th Jan 2017, 06:26 -
searching software to know codec video/audio
By H265 in forum Software PlayingReplies: 7Last Post: 11th Sep 2015, 12:49 -
QUERY: syncing 2 subtitle files written from diff srcs
By andwan0 in forum SubtitleReplies: 2Last Post: 15th Jun 2015, 05:11 -
Video and Audio Syncing
By pboong in forum Newbie / General discussionsReplies: 1Last Post: 5th Feb 2013, 09:09
