    Aug 2017
    Hi All - My first post on this site
    I have a 10 second clip which I dropped into VideoPad (free version).
    I want to split it into single frames. Is there a way to automate this process rather than manually hitting a 4 button sequence x 170 times?
    Any help would be greatly appreciated. Many thanks.
  2. See if you can open it in Virtual Dub Filter Mod (you didn't say what kind of video it is). If it opens, go File->Export->Image Sequence and choose the kind of image you want to save.
    Aug 2017
    Hi manono,
    Thanks for the reply.
    Sorry - it's an .mp4.
    Virtual Dub Filter Mod seems to be for Windows & I am on a Mac.
    Also I'm trying to get to grips with VideoPad - so any help in that direction would be good
  4. Member Budman1's Avatar
    Jul 2012
    NORTHWEST ILLINOIS, USA
    If you can run ffmpeg on your MAC, and I believe you can, its pretty easy to set up a batch file to do it.
    ffmpeg.exe -i "C:\Users\Bud\Desktop\aCommercial HDCNVRTED.flv" -f image2 -vframes 358 "C:\Users\Bud\Desktop\imageFolder\img%05d.jpg
