I get good quality watching on my tv or through my Sony RDR-Hx710. I got a Panasonic nv-gs 550. As living in Europe I use the PAL system.
I use this card http://www.ebay.com/itm/3fach-Firewire-PCI-Express-Karte-c813-/310351192316?hash=item4...wAAOSwjKFZWKon
Brand new cable 4 pin to 6 pin.
I used Avcutty, Dvdate, WinDV and some more.
I get good sound byt i got rough pixels not as smooth as playback on other units. Also diagonal edges on objects expands and are shown as a line of pixels in more fast moment.
Haven't found any settings to solve the problem. I guess I need the right program, recoding settings och change the outcome of the file. (I read about the encoding, that I can't encode while capturing.) My goal is to be able to watch the movies with VLC for example.
Many thanks in advance! Sorry if I ask a question with an answer in the forum. Have a deadline and tried to find an answer.
First off, if you use WinDV there is no alteration between the original camera footage and what you 'capture' to the PC. Never used AVCutty so do not know what, if anything, it does to the footage.
What are you using to view the 'captured' footage ? You appear to be describing an interlacing issue. And that might be an issue with the viewing program rather than the footage itself.
I would suggest to upload a short sample of the original 'captured' footage both from AVCutty and WinDV so that we can get a better idea of what may be going on. -
Many thanks!
Automatic deinterlacing and Yadif 2 is SUPER! I'm very pleased! Thank you all that replied.
Problem putting transferring videos from computer to phone/facebook etc
By Racso_Ssor in forum Video Streaming DownloadingReplies: 2Last Post: 29th Jul 2016, 16:11 -
Video recorded from IP Cam - No audio unless I play back with IP Cam app
By momo123 in forum Software PlayingReplies: 5Last Post: 10th Aug 2015, 13:58 -
Your friend's bad computer habits that drive you nuts.
By Clockwork in forum Off topicReplies: 5Last Post: 14th May 2013, 22:50 -
suitable cam corder with good sound quality for filming sports coaching
By andyknibbs in forum Newbie / General discussionsReplies: 3Last Post: 2nd Mar 2013, 04:36 -
GoPro BAD quality.
By GreenMachine113 in forum EditingReplies: 18Last Post: 5th Nov 2012, 20:22
