  1. Hello, Im trying to extract the video stream from a mkv file so I can use it directly with TMPGEnc so I dont loose that much quality when converting it. Is there a way to do it or the only way is to re compress it before compressing it again with TMPGEnc?
  2. Use an Avisynth script like
    DirectShowSource("D:\file.mkv", convertfps=true)
    as input to TMPGEnc
  3. Member netmask56's Avatar
    Sep 2005
    Sydney, Australia
    or perhaps gMKVExtractGUI and select the tracks you want to extract, no conversion takes place.
  4. extract the video stream from a mkv file
    AFIK TMPGenc doesn't supports elementary streams.
  5. Originally Posted by videobruger View Post
    [Attachment 42865 - Click to enlarge]
    I tried the avs script but its nor supported by TMPGEnc. I have version 2.5
  6. I also have version 2.5 (2.525.64.184) and it supports AviSynth script.
    Did you copy the code above and saved it as a .avs file?
  7. Originally Posted by videobruger View Post
    [Attachment 42867 - Click to enlarge]
    Yes and I got the error message cannot open or unsupported
    PD: I got it working, didnt have the avisynth version correctly installed, thanks
