  1. I'm using latest mkvmerge version to mux video and audio together, but the audio file outputs lots of errors like
    Warning: 'audio.ac3' track 0: This audio track contains 128 bytes of invalid data which were skipped before timecode 00:00:00.000000000. The audio/video synchronization may have been lost.
    eac3to can't even open the file - The format of the source file could not be detected. <ERROR> . But all my media players play file without problems and sync. Mediainfo does recognize file correctly...
    Format : AC-3
    Format/Info : Audio Coding 3
    File size : 266 MiB
    Duration : 1 h 36 min
    Overall bit rate mode : Constant
    Overall bit rate : 384 kb/s
    Audio
    Format : AC-3
    Format settings, Endianness : Big
    Bit rate mode : Constant
    Bit rate : 384 kb/s
    Channel(s) : 6 channels
    Channel positions : Front: L C R, Side: L R, LFE
    Sampling rate : 48.0 kHz
    Frame rate : 31.250 FPS (1536 spf)
    Bit depth : 16 bits
    Compression mode : Lossy
    Stream size : 266 MiB (100%)
    Service kind : Complete Main
    How can i fix/repair/remove invalid data from ac3 file?
  2. You can try ac3fix / ac3fixgui
  3. i already tried, ac3fix says Finished. Found bad frames. Final wrongness is -1644 bytes , but mkvmerge same error invalid data...
  4. I guess you can ignore it if the media players are happy with it
    Maybe try rewrapping it with ffmpeg ? or Try mux/demux with tsmuxer
