Hi
Just digital video from which the player can create internal timecode from framerate and position HH:MM:SS:ff - and read from an input of some sort.
Any standalone players that do this?
Any software players that do this?
It need not display timecode, that I have in daw generating SMPTE code. Just that it gets to same position each time and play in sync.
Grateful for any input.
Thanks.
Thank you.
Forgot to mention I am on PC.
For Mac I also found Video Slave by Non-Lethal-Applications. But next v4.x will also be for Windows, and arrive some time late next year.
Best solution so far is using MIDI and MTC(midi time code) between daws on different computers. So slave another daw on other computer, kind of.
But have to check first with virtual midi cable if it position good enough - best if it at least go to I-frame accurate, but best if frame accurate. -
VidPlayMTC MIDI Time Code Video Player for Windows is now DonationWare.
Free download at https://vidplaymtc.com -
VidPlayVST can be configured as a video server using Vienna Ensemble Pro...
https://youtu.be/8qQ8dQV5mKw -
VidPlayVST now has the option to display SMPTE timecode, including setting an offset value. Useful when scoring to film where there is a convention that frame 0 has timecode 01:00:00:00.
SOLVED mp4 Bigendian smpte st 337 frames detected 1536 kbps cbr, Unplayable
By compscistudent in forum Software PlayingReplies: 10Last Post: 18th Jul 2015, 00:26 -
Standalone hardware media player for TV
By siluet in forum Media Center PC / MediaCentersReplies: 60Last Post: 7th Dec 2014, 21:23 -
Huge Blu-ray playback problem on both standalone and software players.
By Astral in forum Blu-ray RippingReplies: 1Last Post: 7th Nov 2013, 09:44 -
Which Media player reads timecode?
By sp_key in forum Software PlayingReplies: 7Last Post: 20th Dec 2012, 15:22 -
Program to replace timecode in srt with timecode from another srt
By TehBotolSOsro in forum SubtitleReplies: 19Last Post: 13th Sep 2012, 12:28
