I have captured several tapes using an uncompressed codec (CHQX) via. AmaRecTV from a USB capture device.
Three example resultant files (720x576, 25p, PAL):I used HandBrake v1.07 to compress File 2 to MP4 using the program's 'Fast 576p25' MP4 preset.
- File 1 - 1h 6m (8.9 GB)
- File 2 - 1h 38m (16.5 GB)
- File 3 - 4h 4m (40.5 GB)
Whilst the file size reduced to 4.1 GB, the quality is visible not as good as the original capture.
Does anyone have any suggestions?
Although I think I can not help you with encoding settings, but don't use 25p if you want to preserve the motion resolution of 25i of the VHS tapes. Don't change the resolution if possible
The more things are adjusted while transcoding or encoding the worse the result.
x264 is very nice. x265 is also very nice, but maybe playing equipment can not handle it, because it is quite new. But for specific encoding settings here are other guys around who know what they are doing
Video capturing old VHS tapes with lossless format
By kur1j in forum Newbie / General discussionsReplies: 32Last Post: 20th Mar 2017, 10:35 -
Best video format to capture S-VHS video?
By UweZ in forum Capturing and VCRReplies: 10Last Post: 5th Jan 2017, 16:57 -
convert a vhs format video to dvd
By shom44 in forum Capturing and VCRReplies: 13Last Post: 27th Aug 2016, 12:37 -
record video fron VHS-C to another tape format?
By VHS-C98 in forum Newbie / General discussionsReplies: 6Last Post: 20th Dec 2015, 12:37 -
Tips for choosing right video compression & format for lectures
By Omk in forum Newbie / General discussionsReplies: 7Last Post: 8th Oct 2013, 08:24
