Hi
I used to use virtualdub to cut portions of videos down. It was great and fast for avi files but more and more i am coming across mp4 videos.
Is there a good program thar easily allows me to select portions of a video and without spending a bunch of time make a smaller file of just the selected portion? Everything i find seems to want to convert the file and takes forever...
Thanks for any help.
Results 1 to 11 of 11
- VidCutter is not lossless as far as I can tell.
- MKVToolNix can combine MP4s into an MKV but the resulting file wouldn't play correctly for me in multiple players I tried.
- AviDemux 2.7 crashed on me when I tried concatenating some files, something about an audio issue.
- VirtualDubFilterMod doesn't support generic multi selection, only a very specific filename sequence pattern is supported for multiple selection. And you have to open the first file and only then append the rest (probably one by one). Plus you can't output an MP4 file using direct stream copy.
- MP4Tools MP4Joiner might do the trick but its installer was bundled with some unwanted software and its interface was slow so I didn't even try.
My best experience was with MP4Box. I wanted a GUI so tried my MP4Box GUI but that didn't work for me, so I switched to YAMB. It's a little annoying because you can't drag and drop, but it does support multiple selection which is good enough for me. Make sure to replace its bundled mp4box with the latest version though.Last edited by labBat; 15th Dec 2017 at 05:38.
VirtualDub FilterMod is still being developed so you might want to get in touch with the developer, Shekh, and see if he can/will do anything.
There's actually a ticket for it here:
https://sourceforge.net/p/vdfiltermod/tickets/79/
Regarding MP4 concatenation, Shekh said:
Doesn't work that way. https://sourceforge.net/p/vdfiltermod/wiki/direct_copy/
For such task better try another program. -
Ah. I assume you've tried VideoRedo? I know it's not free but I've never regretted buying it. And, in addition to all that it does, the support from the multiple Dans and the rest of the team on their forum is excellent.
[Just to be clear, as far as I'm aware, I'm not in any way connected to either the company or anyone involved in the making of VideoRedo. I'm just a happy user of the software.] -
I'd use mkvToolnix GUI for this.
"appending" MP4's is simple
You cant preview by frame like virtualDub but if you know the timecode or lengths you want to cut it's pretty simple.
It will kick your MP4's out as MKV but if you dont want that (and why wouldnt you?) you can always
just downgrade back to mp4 with WinFF - it only takes a few seconds.
(And you get the other cool tools it offers too) -
Stiiv
How to open .MP4 files in virtualdub? (i want to sharpen mp4
By fuc847 in forum Video ConversionReplies: 27Last Post: 22nd Apr 2015, 09:06 -
Merge mp4 files without reencoding with Virtualdub ?
By ramaflore in forum Newbie / General discussionsReplies: 43Last Post: 24th Feb 2015, 04:19 -
Opening MP4 Files in VirtualDub
By mkh in forum Software PlayingReplies: 1Last Post: 16th Feb 2014, 18:13 -
Alternative to VirtualDub for MP4 ad block cutting + Changing container
By falco2000 in forum Newbie / General discussionsReplies: 5Last Post: 28th Feb 2013, 10:20 -
Transcode 3gp and MP4 files using VirtualDub and Avisynth
By effes in forum Newbie / General discussionsReplies: 16Last Post: 19th Sep 2012, 16:20
