Hi, I need advice for something I want to do with VCR to PC image transfering.
I have bought a video capture usb (RCA to usb) but there is a problem with the image... It's shaking right and left.
Like this https://www.youtube.com/watch?v=OwtqqhVU0I4
Firstly, let me tell you that when I connect the VCR to the TV the image is fine.
Also when I connect a DVD player (a device way newer than the VCR) to the PC through the same usb, the image is also fine.
So, something must be wrong when the analog-to-digital signal converting is happening.
It's like the TV sees this problematic image and has a way to fix it somehow.
On the other hand, the usb doesn't have a way to fix it, so I have this shaking image.
So, my questions is...
What are the possible explanations/causes for this??
Usb device quality?? VCR quality??
What system has a TV to fix a VCR shaking image??
Is there a software or some settings for PC that do the same fix a TV does??
Thank you.
(if you don't know how to help me, can you please give me a link with people who know more about these devices?? Some digital engineers maybe??)
Results 1 to 11 of 11
Do a forum search for TBC or Time base Corrector. All will be clear to you then.
If you have a dvd recorder (not a player) you can daisy-chain that between the VCR and the capture device and that should solve your problem. -
Thanks, I have read about the TBC, but I wasn't sure this was the case, because the usb works fine with the dvd player.
About the dvd recorder, yeah, I know. If I had one, I wouldn't buy this cheap usb. :P -
DVD players are digital devices with perfect sync. VHS decks are analog and have poor sync.
I assume you used PAL when setting up the USB device?
Many people make the mistake of skipping the "tuner setup" thinking that they won't be using it as a "tuner", just line-in capture. Go through the (software) setup and make sure it is set to PAL. That is exactly how I switch mine between PAL and PAL60(NTSC tape in a PAL VCR).
You also may want to mention the make and model of the capture device. -
Yeah, I tried every option in the settings. Nothing seems to work.
In another forum someone said the cause is the low quality of both VCR (an old sony) and usb device (easyCap).
Yeah, I know it's a fake one, but as I said before, I thought that if dvd player works, then maybe I can find a way to make it work with the VCR.
I guess I was too optimistic. -
Well you have been told how you get it to work with your VCR.
And straight to dvd-recorder is only a quick fix since you would probably be disappointed with the results then. And not so easy to edit without losing quality.
If your 'fake' easycap was so bad you would not even be able to get the picture you receive.
VHS tape got stuck in VCR, now VCR plays full static
By Rand251 in forum Newbie / General discussionsReplies: 21Last Post: 4th Apr 2016, 09:40 -
Capturing VHS with VCR or Blu-ray/VCR combo?
By SyncroScales in forum Capturing and VCRReplies: 11Last Post: 26th Dec 2014, 08:39 -
Connection conundrum
By pheasant1950 in forum AudioReplies: 1Last Post: 16th Jun 2014, 12:30 -
Wireless Optical Connection
By twinsons32 in forum Newbie / General discussionsReplies: 1Last Post: 22nd Jan 2014, 18:06 -
Is this VCR a Super VHS VCR?
By avz10 in forum Capturing and VCRReplies: 9Last Post: 29th Aug 2012, 00:46
