Results 1 to 9 of 9
  1. is it possible to make vobsubs larger/smaller in dimensions using MKVToolNix?
    Sep 2013
    Europe
    .idx + .sub ? If so, they are images. You have to rebuild them using the appropriate tool such as SubtitleEdit, Subtitle Creator...
  3. Member netmask56's Avatar
    Sep 2005
    Sydney, Australia
    Maybe getting SRT text based version or converting them using OCD .
    Jan 2001
    VOB subtitles are better in the long run, SRT is dull text lol
    Image based subs will always be better.
    #1 PGS
    #2 VOB
    In other words, leave them untouched.
  5. Originally Posted by netmask56 View Post
    LOL. OCR might be preferable!
    Jan 2001
    keep the original vob subs my friend
    srt is the lower end subtitles
  7. vob subs suck. They scale poorly, you can't control the font, colors, transparency, drop shadows, etc.
  8. Mr. Computer Geek dannyboy48888's Avatar
    May 2007
    Texas, USA
    Short answer not easily. You can extract them and resize with bdsub2sup (does more than bd subs). Useful for upscaling subs with upscaling video. for fine adjustments you have to ocr them then remake them as said before
    Option 3 would be check your player for size adjusting.
    if all else fails read the manual
    I agree. I always convert the ones that came on the DVD to subs to my own liking.
    To answer the question, though, the IDX file of VobSubs can be edited so that they appear larger or smaller when viewed with the video. But not by using MKVToolnix, but by editing the IDX file of the VobSubs. Open the IDX in Notepad. Originally (for NTSC subs) they say this near the top:
    # Original frame size
    # Origin, relative to the upper-left corner, can be overloaded by aligment
    org: 0, 0
    To make them smaller you can change that part so it reads:
    org: 200, 220
    The pictures below show the result, with the original size on the left and the reduced size on the right. Maybe not all players will recognize the changes but, as I said, I don't use the original VobSubs anyway.
