i basically just need to change the frame rate of the subtitles,how can i do that?
	BDSup2Sub. Or mux using Mkvtoolnix and set "Stretch by" of the subtitle track to [source fps]/[target fps].
 brilliant! just one more question,is it possible to make vobsubs larger or smaller in size (dimensions) using MKVToolNix?
 currently they cover half of the screen,and i understand that text wraping wont change.i just want to make them smaller so it easier to tell what going on in the video.
  Free bluray converter to h.265(convert your 25GB bluray film to just 500mb)By david55 in forum Video ConversionReplies: 3Last Post: 4th Nov 2014, 12:15
  create vobsubs for 1080 or 720 resolutionsBy artoodeeto in forum SubtitleReplies: 4Last Post: 16th May 2014, 18:46
  Bluray player not playing Sub/Idx for xvidBy spiritgumm in forum SubtitleReplies: 20Last Post: 28th Jun 2013, 18:29
  Editing VOBSUBsBy Trismegistus in forum SubtitleReplies: 2Last Post: 3rd Nov 2012, 22:17
  Is possible to use idx/sub subtitles in DVD without convert them?By mygh in forum SubtitleReplies: 1Last Post: 12th Sep 2012, 03:41
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
