I am running into some issues when editing interlaced footage. If I don't cut on the right field, QTGMC results in jerky footage. Problem is I batch script QTGMC and not knowing if I cut on a top or bottom field prior messes up by workflow (even if I did know, it would still mess up my workflow). So is there a simple way to tell if one is cutting on a bottom or top field in an NLE to ensure one is making proper cuts?
If you are cutting at frames: if the video is TFF you are always cutting between the bottom field of one frame and the top field of the next. If the video is BFF you are always cutting between the top field of one frame and the bottom field of the next. Jerkiness after QTGMC would only be an issue if you are editing telecined film (and it would only be a frame or two at each cut). In that case you should IVTC before editing.
If you are separating the fields before cutting, then weaving the fields back together, you will end up switching the field order if you cut at a mix of even and odd field numbers. This will cause QTGMC to get jerky in the sections where the field order is reversed. Always cut at even field numbers. -
Thanks for the responses guys. This isn't telecined content. And both of you are right, whether I cut at 1:00:00 or 1:00:01, I am still cutting on the frame. I just got really confused trying to troubleshoot what was going on. For some strange reason, even though this is supposed to be BFF/LFF, the field dominance somehow got reversed. I have no idea how or why. I figured this out after playing with different cuts and realizing that the only fix was to change the field dominance.
I'm trying to author a DVD with .ass subtitle (top and bottom) and menu
By deadfinger in forum Authoring (DVD)Replies: 15Last Post: 31st Oct 2016, 17:34 -
How to convert a Top-Bottom mkv-file to SBS
By ErwinForum in forum Video ConversionReplies: 0Last Post: 17th Feb 2015, 07:18 -
using handbreak top and bottom video parts missing?
By BaaGGHo in forum Newbie / General discussionsReplies: 4Last Post: 10th Jun 2013, 16:41 -
How to hardcode 2 subtitles - on top and bottom of the video?
By dim4x4 in forum SubtitleReplies: 8Last Post: 7th Apr 2013, 15:34 -
Sony Vegas adding Hollywood Style top/bottom borders? possible?
By Xander13 in forum EditingReplies: 6Last Post: 8th Mar 2013, 00:37
