I know how to make screenshots. But, would it be possible to make stills from a DV-file that are of a better quality than screenshots? And if yes, how?
DV-files are interlaced. So I suppose one frame must be assembled from two successive frames.
One frame comprises two fields. The very highest quality will come from using an intensive deinterlacer like Avisynth's QTGMC, then grabbing your stills in an app that has snapshot capability, such as VLC or VirtualDub.
VirtualDub:
Video -> Filters -> Add -> Deinterlace, Interpolate using Yadif, Double frame rate, bottom field first
Video -> Copy output frame to clipboard
Paste from clipboard in an image editor. This is won't be as good as QTGMC() but it's much easier if you aren't experienced with AviSynth. -
PNG is compressed but losslessly. Uncompressed TIFF can only be bigger, not better quality.
Your Best method to make 50i to a 50p file
By diginoob in forum RestorationReplies: 18Last Post: 29th Aug 2016, 06:38 -
Is there a way to make very minor text edits to a SUP or SUB file?
By haggis999 in forum SubtitleReplies: 18Last Post: 1st Apr 2015, 18:48 -
what ripbot settings were used to make this file
By nstream in forum Blu-ray RippingReplies: 1Last Post: 13th Nov 2014, 03:10 -
What Are The Encoder Settings Used To Make This File?
By nstream in forum Video ConversionReplies: 11Last Post: 15th May 2014, 18:31 -
How do i make a mini mkv file?
By brotherhood1997 in forum Newbie / General discussionsReplies: 28Last Post: 27th Apr 2014, 21:40
