Results 1 to 9 of 9
Thread: Playing blu-ray discs on VLC? (What am I doing wrong?)
  1. #1
    Member gastrof's Avatar
    Sep 2004
    comfy chair
    Posts
    261
    I installed a blu-ray drive in my computer. Using the 64-bit version of VLC, I tried to play my first blu-ray disc today.
    It says it can't play the disc. (Keeps saying "Your input can't be opened.")
    There was a video on YouTube saying you need to download a "key database". (https://www.youtube.com/watch?v=zHdZWMb3qZk)
    I've looked for the link he promised would be listed below the video, but couldn't find one. I've poked around on the VLC site. Can't find it there either. (Well, the video is over a year old. Things may have changed.)
    My VLC installation is fairly new, and it insists it's the newest version (no updates being available). It works fine with .mp3 files and DVDs, as well as video files.
    Anyone have any ideas?
    Member
    Feb 2006
    Posts
    2,844
    Re: Playing blu-ray discs on VLC? (What am I doing wrong?)
    i think you need to install the vlc blu ray plug in - https://www.videohelp.com/software/VLC-media-player
    Sep 2004
    comfy chair
    Posts
    261
    Quote Originally Posted by october262 View Post
    I don't mean to be disrespectful, but is that a safe link? I now know it seems to be the same one the guy used in the video, but it doesn't appear to be from VLC/Videolan.
    Member
    May 2014
    Memphis TN, US
    Posts
    2,031
    The link provided is in the videohelp software section on the website you're currently viewing. A direct link to the plugin download is farther down on the linked page under "More information and other downloads". That link takes you to vlc at http://vlc-bluray.whoknowsmy.name/.
    - My sister Ann's brother
    Member DB83's Avatar
    Jul 2007
    Posts
    10,081
    And if you read the comments on that yt page you will glean that many BDs will not work simply because the key is not in the database or not available elsewhere.
    Add that the instructions only refer to Win10 and a Win7 install is different.
    I'll stick to PowerDVD and Passkey. Yeah. These cost $$$ but atleast they will work without hassle.
    Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    Posts
    6,601
    While VLC will play some discs (as noted above) it does not officially support Blu-Ray and will not play all discs.
    Google is your Friend
    Sep 2004
    comfy chair
    Posts
    261
    Quote Originally Posted by LMotlow View Post
    I finally went to download the Blu-Ray codec, and got this on the page that came up-
    Your connection is not secure
    The owner of vlc-bluray.whoknowsmy.name has configured their website improperly. To protect your information from being stolen, Firefox has not connected to this website.
    I got something similar when using EDGE.
    Anyone got any ideas?
    Member
    Mar 2008
    Posts
    7,600
    Seems as if the security certificate at the site has expired ...
    A more up to date database, done by users, can be found here.
    https://forum.doom9.org/showthread.php?t=120988
    To play my own discs I had to extract the keys myself and add it to the database, you'll have to do the same if your discs are not in that file.
  1. Leawo Blu-ray Player: Problems Playing Blu-Ray Discs
    By devilcoelhodog in forum Software Playing
    Last Post: 24th Mar 2017, 07:32
  2. LG blu-ray player is stopping playing blu-ray discs
    By mausinho in forum DVD & Blu-ray Players
    Last Post: 22nd Feb 2016, 08:55
  3. Playing Blu-Ray discs on the PC
    By rotchild in forum Newbie / General discussions
    Last Post: 8th Sep 2014, 20:01
  4. Replies: 63
    Last Post: 23rd Feb 2014, 21:34
  5. Replies: 2
    Last Post: 20th Dec 2013, 10:55
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
