Hi,
I'm trying to build FFmpeg using MSYS2 and MINGW64 in Windows 10 64-bit. How to check that I've done the building process correctly?
I tried to check it by running this code:
And I got this result:Code:$ ffmpeg --version
Does it mean FFmpeg was installed correctly? Or are there any other ways to check?Code:ffmpeg version N-86942-geabeb90 Copyright (c) 2000-2017 the FFmpeg developers built with gcc 7.1.0 (Rev2, Built by MSYS2 project) configuration: --enable-shared libavutil 55. 69.101 / 55. 69.101 libavcodec 57.102.100 / 57.102.100 libavformat 57. 76.100 / 57. 76.100 libavdevice 57. 7.100 / 57. 7.100 libavfilter 6. 98.100 / 6. 98.100 libswscale 4. 7.101 / 4. 7.101 libswresample 2. 8.100 / 2. 8.100 Unrecognized option '-version'. Error splitting the argument list: Option not found
Thank you...
[SOLVED]Use ffplay to check how much to brighten video before using ffmpeg?
By yetanotherlogin in forum EditingReplies: 1Last Post: 16th Mar 2016, 04:59 -
How to get & install FDKAAC on FFMPEG?
By EdsonMarques in forum Newbie / General discussionsReplies: 1Last Post: 16th Jul 2015, 06:10 -
How to check if *.mkv video is internally correctly encoded?
By pxstein in forum Video ConversionReplies: 2Last Post: 20th Mar 2015, 12:23 -
Ffmpeg won't install
By macbuz in forum ffmpegX general discussionReplies: 6Last Post: 12th Aug 2014, 00:20 -
FFMPEG - Adding Audio to Video Not Working Correctly
By Endemoniada in forum Video ConversionReplies: 3Last Post: 31st Jan 2013, 06:18
