Dear whoever is reading this!
I need help with my sony vegas.
I recently downloaded it and I have a problem
When I added a song to my timeline at the last moment, the clip suddenly disappears and I don't know why when clicked on the invisible clip the preview showed the video but it wasn't on the timeline so I need help quick! it's for a project
OneGamer, in the future please use a more descriptive subject title in your posts to allow others to search for similar topics. I will change yours this time. From our rules:
Thanks,Try to choose a subject that describes your topic.
Please do not use topic subjects like Help me!!! or Problems.
Moderator redwudz -
1. Remember, there is a play button which plays media that is in the bin or in the explorer view. There is another play button for media that is on the timeline. You have to drag the video (or audio) to the timeline so you can actually do something with it. The play button used with the media bins and explorer view are there just to help you select the correct clip to put onto the timeline.
2. There is also a trimmer function to help you trim clips before you import them to the timeline. Once again, this is a feature to help you preview the clips before you actually put them into your project. You still have to drag them into the timeline.
Sony Vegas - Strange problem with Sony AVC/MVC rendered files
By RMCF10 in forum Newbie / General discussionsReplies: 16Last Post: 5th Feb 2016, 05:04 -
AVCHD rendering @60p w/ Intel Quick Sync Video problem - Vegas Pro 13
By Hambert in forum EditingReplies: 3Last Post: 19th Aug 2015, 12:44 -
Sony Vegas 8 Won't Open a Vegas File?
By leelou in forum EditingReplies: 10Last Post: 4th Aug 2013, 15:36 -
Difference in price between Sony Vegas Pro 11 & Sony Movie Studio Platinum
By Ghost Dust in forum Newbie / General discussionsReplies: 8Last Post: 11th Feb 2013, 13:42 -
How can I do something like this in sony vegas?
By gil900 in forum EditingReplies: 20Last Post: 8th Dec 2012, 08:00
