    Apr 2005
    Hi
    I use TS-Doctor 2.0 to extract subtitle on the TV-show I recording.
    I do not use the GUI but instead I use a script that I have create to run fron CLI.
    The problem is that even I have look inside the settings it still ask yes or no if a file have "Scrambled stream areas detected" as default I want to have no but.
    I can't find it how to make it default so I don't need to click
    If I look in the versions history I find this:
    1.2.16 - Dialog settings for "Scrambled stream areas detected"
    But I can't see that in my version, sure I use 2.0 but it have to be strange if it not even is in 2.0
  2. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    I've not used it. But it's not uncommon for options to change or be missing when software goes through major changes.
    Google is your Friend
  3. Member netmask56's Avatar
    Sep 2005
    Sydney, Australia
    Apr 2005
    ohh I was there but it was hard to understand German when I was trying to registrate but now is a little easy with the link. thanks
