Hi all,
Can you pass on your wisdom to a newbie please. I am trying to find the correct video size setting on the AVC converter that ensures each file I convert to .MP4 fills the 'whole screen' on the converted file - so it does not have the vertical black lines top and bottom.
Thanks in advance
Chris
	Are all iPad displays 4:3? Then you would have to choose a resolution where width * 3 = height * 4.
 Since most content nowadays is 16:9 or even wider that means you must stretch and/or crop accordingly. But is there no player on iPad that could stretch during playback?
 "the AVC converter"? Which one? There are thousands.
 [Attachment 42762 - Click to enlarge]
 Hi this is what im using - its the video size (highlighted) i need to get to fit the whole screen if its possible to do
  What is my best option for iPadBy Tafflad in forum Video ConversionReplies: 9Last Post: 20th Jun 2017, 16:44
  Stream from PC to iPadBy TBaker14 in forum Video Streaming DownloadingReplies: 7Last Post: 17th Mar 2015, 12:11
  Subtitle playback for iPadBy FrozenPhoenix95 in forum SubtitleReplies: 3Last Post: 23rd Jan 2014, 15:54
  iPad Corner DentsBy SIRCOOKS in forum ComputerReplies: 3Last Post: 1st Mar 2013, 09:07
  Wrong ratio on ipadBy Nirak in forum MacReplies: 2Last Post: 4th Dec 2012, 09:31
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
