Hello from the newbie-est of Nuubs.
I have an instrument that uses the Planar EL560.400 Monochrome Flat panel display.
Besides power, this panel is VGA format, needing Vid data, Vid clock, Horiz. Sync and Vertical sync.
The panel went "blooey" and used replacements (long out of production) cost more than the
instrument is worth.
The panel is VGA with an odd-ball 560x400 resolution that cannot be changed.
I built a patch cord and ran the VGA signal to a common HP PC VGA monitor, using the
GREEN input to take the "Vid Data" and leaving the Red and Blue unterminated.
I get good video and good Horizontal sync, but no Vertical sync. None of the monitors
I've tried can "stretch" enough to lock at the odd resolution.
Is there a device (less expensive than the replacment panel) that can convert
this 560x400 video into something like 640x480, so a common monitor can work?
Or are there old monitors out there that might display this?
Thanks!
David S.
I can imagine display with significantly higher resolution to reduce rescaling errors.
Old 400 line resolutions were often interlaced (ie, NTSC compatible). Most modern computer monitors won't sync to that. An old Amiga or CGA monitor should.
Or maybe an old multisync (multiscanning) monitor, if you can find one.
Edit: not to be confused with multifrequency monitors.Last edited by Keyser; 6th Aug 2017 at 11:09.
"The greatest trick the Devil ever pulled was convincing the world he didn't exist." -
Oops, I forgot: CGA monitors were digital, not analog. So that won't work.
This type of passive VGA to composite adapter might work:
http://sandacite.com/forum/index.php?topic=2431.0
The output will be composite video ready for a TV.
Thinking about this a bit more, are you sure the output of the device is analog VGA? It could be digital CGA. Check the voltages with a oscilloscope. VGA will be analog ranging from 0 to 0.7 volts on the RGB pins, 0 and 5 volts on the sync pins. CGA will be digital, 0 and 5 volts. CGA also has an intensity bit. Also, what are the vertical and horizontal refresh frequencies?Last edited by jagabo; 8th Aug 2017 at 08:08.
Where can I get USB 3.0 to Firewire 400 converter?
By Videogamer555 in forum Capturing and VCRReplies: 27Last Post: 13th Feb 2018, 09:04 -
Interested in buying an Popcorn Hour A-400 but...
By Divvy in forum Media Center PC / MediaCentersReplies: 9Last Post: 4th Sep 2014, 16:58 -
Apple stock plummets to $400/share as iPhone sales slump
By deadrats in forum Newbie / General discussionsReplies: 1Last Post: 25th Jun 2013, 11:00 -
Streaming to TV solution!
By Luna72 in forum Media Center PC / MediaCentersReplies: 8Last Post: 17th Apr 2013, 08:08 -
WD My Book Live & Popcorn Hour A-400 streamer
By jamesj84 in forum Media Center PC / MediaCentersReplies: 3Last Post: 7th Jan 2013, 10:39
