Edit: Not sure if my title change worked or not, it should read "How did Pre-CSS crack DVD copying work?"
Random thought that's been floating around my mind for the past few weeks...how did Pre-CSS crack DVD copying work? I'm sure the answer is somewhere here in the forums, but I seem to recall that it was somehow an internal frame by frame decoding (capture?) that would take days (up to 48-72 hours per disc sticks in my mind) with the disc continually spinning. And how was the audio copied?
I remember experimenting and starting to copy a DVD back then and stopping before it was done (because of stories of burnt out drives due to overuse), but don't remember if there was a partial file or not.
Okay, those braincells are now free to think about something else useless!
It was basically screen + audio capturing, problem back then was to get to the right interfaces and have enough processing power to playback the dvd (using a legal player software) and at the same time capture both audio&video (with a small buffer) and encode to something else. (this was around 1998-2001 in the early days of MPEG-4 ASP)
Nowadays any decent screen capturing tool can do it that way.users currently on my ignore list: deadrats, Stears555
Funai ZV427FX4 copying VHS to DVD, DVD doesn't work
By Paladyr in forum Newbie / General discussionsReplies: 6Last Post: 29th Dec 2014, 13:52 -
No loss way to decrypt, edit, and burn DVD from a CSS encrypted DVD?
By fdecker in forum DVD RippingReplies: 7Last Post: 14th Oct 2014, 12:09 -
Can't get my Pre-Amp card to work!!
By rayjaymor85 in forum Media Center PC / MediaCentersReplies: 0Last Post: 15th Jun 2013, 12:46 -
Help copying videos, coojah6 and blaader use to work for me but not now.
By kentuckynet in forum Video Streaming DownloadingReplies: 3Last Post: 9th Jan 2013, 20:43 -
Question about blu-ray copying and equipment
By The Burning Man in forum Blu-ray RippingReplies: 5Last Post: 19th Dec 2012, 09:18
