Hello
I tried joining those two MP4 files with different applications, but none worked because the video streams were encoded differently:
FILE #1
FILE #2Code:Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'FILE.1.mp4': Metadata: major_brand : isom minor_version : 512 compatible_brands: isomiso2avc1mp41 creation_time : 1970-01-01T00:00:00.000000Z encoder : Lavf52.92.0 Duration: 00:12:55.38, start: 0.000000, bitrate: 539 kb/s Stream #0:0(eng): Video: h264 (High) (avc1 / 0x31637661), yuv420p, 640x480,697 kb/s, 29.97 fps, 29.97 tbr, 2997 tbn, 59.94 tbc (default) Metadata: creation_time : 1970-01-01T00:00:00.000000Z handler_name : VideoHandler Stream #0:1(eng): Audio: aac (LC) (mp4a / 0x6134706D), 44100 Hz, stereo, fltp, 127 kb/s (default) Metadata: creation_time : 1970-01-01T00:00:00.000000Z handler_name : SoundHandler
Is there a way to join them somehow?Code:Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'FILE.2.mp4': Metadata: major_brand : isom minor_version : 512 compatible_brands: isomiso2avc1mp41 creation_time : 1970-01-01T00:00:00.000000Z encoder : Lavf52.92.0 Duration: 00:10:05.02, start: 0.000000, bitrate: 361 kb/s Stream #0:0(und): Video: h264 (Constrained Baseline) (avc1 / 0x31637661), yuv420p, 296x224 [SAR 1:1 DAR 37:28], 359 kb/s, 25 fps, 25 tbr, 25 tbn, 50 tbc (default) Metadata: creation_time : 1970-01-01T00:00:00.000000Z handler_name : VideoHandler Stream #0:1(und): Audio: aac (LC) (mp4a / 0x6134706D), 44100 Hz, stereo, fltp, 95 kb/s (default) Metadata: creation_time : 1970-01-01T00:00:00.000000Z handler_name : SoundHandler
Thank you.
You will need to re-encode them with identical parameters to successfully join them.
SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851 -
Thank you.
Can ffmpeg/ffprobe tell me what settings to use to reencode?
→Code:Video: h264 (High) (avc1 / 0x31637661), yuv420p, 640x480, 697 kb/s, 29.97 fps, 29.97 tbr, 2997 tbn, 59.94 tbc (default)
Code:Video: h264 (Constrained Baseline) (avc1 / 0x31637661), yuv420p, 296x224 [SAR 1:1 DAR 37:28], 359 kb/s, 25 fps, 25 tbr, 25 tbn, 50 tbc (de fault)
Please Help! Date and Time issues mp4 Encoded vs Created
By milkieed in forum Newbie / General discussionsReplies: 38Last Post: 7th Nov 2018, 17:18 -
Encoded .mp4's Are Corrupted After Tagging
By Superfield in forum Video ConversionReplies: 8Last Post: 18th Feb 2016, 19:21 -
Joining Panasonic 4K MP4 files with HD Writer AE 5.2
By Benoit in forum EditingReplies: 9Last Post: 14th Jan 2016, 07:36 -
Weird judder in encoded mp4?
By The.King in forum Video ConversionReplies: 109Last Post: 17th Sep 2015, 14:25 -
joining mp4 videos
By juodas in forum Video ConversionReplies: 2Last Post: 25th Mar 2013, 15:37
