Results 1 to 9 of 9
  1. Hello.
    From other threads, I know that SubtitleEdit can convert TTML2+PNG to *.sup . But this time I have a lot of Subtitle to do, it has been a heavy work because I convert it one by one. Is there any other better way?
    Thanks very much.
  2. Subtile Edit CLI?
  3. Originally Posted by videobruger View Post
    Subtile Edit CLI?
    Thank you for your prompt reply. I already tried that, but it seems that TTML2 is not suported on command line. T_T
  4. Originally Posted by Nikse View Post
    I’m truly grateful for your help! The latest beta is excellent .
  5. Originally Posted by Nikse View Post
    Hello. I found another problem. When I use SubtitleEdit open xml file (TTML2+PNG) , the timecode like "00:04:59.8" will be change to "00:04:59.008", the right timecode should be "00:04:59.800". And some timecode will be lost, like the 71th line in my file subtitle02.xml (begin="00:05:31.122" end="00:05:34")
    Could you fix it please? Thanks very much.
    Jul 2011
    Denmark
    Thx for the info - new beta up: https://github.com/SubtitleEdit/subtitleedit/releases/download/3.5.3/SubtitleEditBeta.zip
  7. Originally Posted by Nikse View Post
    Thanks very much! And I'm so sorry that I want to submit another problem.
    When the xml file (TTML2+PNG) converted to *.sup file or *.sub file, all the position of Subtitles will be changed to middle bottom though it should be on the left or right side of the screen. (I have uploaded a sample)
