  1. Greetings,,
    What I need to know is how do I sync my subtitles with the audio language? I have been using MKV Merge, but to no avail, after muxing, the audio and text are not in sync. I use Formal Factory to hardcode the subtitles so that they will display on a DVD after burning.
    I basically just need to sync the subtitles. Is Subtitle Edit my best bet for this?
    Thanks.
    Aug 2010
    San Francisco, California
    That's what I use. The audio waveform display makes it a snap.
  3. joollyjohn jollyjohn's Avatar
    Mar 2005
    Sydney Australia
ID:	43007I use Potplayer-64 Bits, I time the subs and then I save the file, but keep an original copy.
  4. Originally Posted by jarod1005 View Post
    Normal people don't burn them into the video but make the subtitles selectable. Hardcoding subs unnecessarily degrades the video.
    Where did you get these subs? There's a fair chance you have a PAL<->NTSC problem. That is, the subs may have come from one and need to be converted to the other. Perhaps with a delay added as well.
    Did you try out JVRaines' suggestion? I also synch up subtitles by using an audio waveform (but using SubStation Alpha).
  5. Subtitle Edit or Subtitle Workshop are good programs to help you sync your subtitles.
  6. Thanks, I will try them all. I have subtitle edit and avidemux. The timing of the text and audio will be my toughest task.
    Sep 2017
    Connecticut, USA
    Aegisub is what I use.
