Results 1 to 14 of 14
  1. Hi *** *'* * ***
    please I wonder if there is a practical way to tell to ffmpeg to show the percentage of encoded, or - for cats only - to see a progression bar of encoded.
    canada
    Please wait for another couple days before bumping your thread,i deleted the other 3 bumps.
  3. No ffmpeg itself doesn't show progress in percent.
    There are tons of tools/front ends/wrappers that do, so either use another tools that calls ffmpeg (or write one yourself) or stick with the way ffmpeg indicates progress.
  4. @echo on
    ffmpeg ...
    pause
    :end
    JE SUIS CHARLIE !!!
  5. You do realize that ffmpeg reports the timecode position during an encode? Maybe not quite the same as a progress bar, but if you know that your video is 10 minutes in length, and ffmpeg is currently reporting it is at 2:00:00 and encoding at 18 fps a 30 fps clip then you can quickly calc the amount completed and time left e.g. 20% done and ~13 minutes until completion.
  6. yes but I'm a *** , please I need some examples of use. Some commandlines in practice
  7. I have read but is too complicated, what is AJAX, PHP? Seems they have developed some procedure in other enviroment than windows
    I wonder if there is a practical way, here
  8. Sadly, ffmpeg itself still cannot show a progress bar.
    Thus, i recommend giving the brand-new ffmpeg-progressbar-cli a try:
    It's a thin wrapper for ffmpeg and shows a colored, centered progress bar and the remaining time.
    Also, it's based on Node.js, actively developed and open-source.
  9. thank you cat, but I'm not able to install the program
    I have windows 10 ver 1607 build 14393.447
    I have download and install node-v10.9.0-x64.msi
    And download ffmpeg-progressbar-cli-1.3.0.zip
    for example I decompress all file of the ffmpeg-progressbar-cli-1.3.0.zip in c:\me so that I get:
    and in c:\me\lib:
    cClick image for larger version
    I lauch the cmd prompt and I go in c:\me (or c:\me\lib but don't chage nothing) and I get this error when I try to install the program:
    what I mistake? thanks
  10. Originally Posted by marcorocchini View Post
    Dear marcorocchini,
    thanks for your feedback and the provided documentation.
    The issue regarding the installation of ffmpeg-progressbar-cli occurred to a missing "Git" installation on your PC,
    however, the latest version (v1.4.0) does not have that requirement anymore, your edge case has been taken into account. Please retry installing.
    Furthermore, please use Github Issues for support and feedback in the future, as that page is visited and updated much more frequently than this thread .
    Cheers,
    S
  11. This is obviously necromancing an old thread, but another option for a command-line ffmpeg wrapper with a progress bar is the python package ffpb.
    You install it with pip (pip install ffpb or pip3 install ffpb).
    After that, you'll have a command called ffpb that uses the exact same syntax as ffmpeg itself.
    Here's some output from it being used on a movie with burning subtitles.
    ffpb -i filename.mp4 -vf subtitles=eng.srt:force_style='FontName=DyslexicLo gicFont' -c:a copy
    outfile.mp4
    filename.mp4: 45%|██████████████▎ | 97752/219384 [30:33<35:29, 57.12 frames/s]
    But apparently, it doesn't work when you set the log level low or use "--ss/--to/-t" arguments.
