Does MMC 7.6 install straight out or does it need tweks to get it to work with an ATW VE ?
ATI has MMC 7.1 only for the ATW VE.
TIA.
You install the WDM drivers supplied with 7.1, but then don't install MMC (7.1) Download 7.5 and 7.6 from filemirrors.com, take the setup.inx file from 7.5 and overwrite it in 7.6 (installer directory, PRE-install) and then install 7.6 - not supported though (officially) so no guarantees it will work. Judging by the fact that you bought the VE, if you only need a TV tuner, 7.1 will do just fine!
jpb
Videosoap in ATI MMC. Couple of questions
By andrewjameshoward in forum Capturing and VCRReplies: 1Last Post: 10th Dec 2009, 13:49 -
Anybody know how to get ATI MMC version 9.02???
By pukhog3 in forum Capturing and VCRReplies: 10Last Post: 10th Sep 2009, 18:12 -
How to use ATi MMC Multimedia Center TV
By c627627 in forum User guidesReplies: 2Last Post: 8th Apr 2009, 04:14 -
More ATI MMC questions. (I RTFM'd.)
By palouse in forum Capturing and VCRReplies: 5Last Post: 13th Jun 2007, 21:08 -
where to download old ATI MMC?
By mencius in forum Capturing and VCRReplies: 2Last Post: 23rd May 2007, 00:44
