Hello,
I'm hoping you can assist me in finding software that can help me face swap in videos, that is, replace one face with another face.
I'm on a Mac, but the options seem somewhat limited there, so I'm widening the scope of my search to include Windows software. The ideal solution would be an app dedicated to face swapping, hopefully for under $100, though I'm ruling nothing out at this point.
In another thread in the Mac section a helpful poster suggested Abode After Effects, which is the most powerful solution I've seen so far. I may go that route, but before I do I thought I'd do more research first to see if anything simpler and cheaper is available. Windows software suggestions welcomed.
Thanks for any advice you may be able to share.
Results 1 to 1 of 1
Extracting thief's face from video
By anonan in forum RestorationReplies: 6Last Post: 28th Oct 2015, 09:50 -
How to change a face in video
By pottendarm in forum EditingReplies: 7Last Post: 25th Sep 2013, 17:57 -
match the face to the buns
By vhelp in forum Off topicReplies: 0Last Post: 27th Aug 2013, 20:11 -
Swapping Eyes in 3D SBS Encoded file??
By tommy2010 in forum Video ConversionReplies: 6Last Post: 4th Dec 2012, 23:05 -
funny hdd noise, swapping or thrashing
By vhelp in forum ComputerReplies: 3Last Post: 31st Oct 2012, 20:03
