Is it possible to decipher the manufacturing year of my MDisc DVDR Verbatim made in Taiwan?
Closed Thread
Results 1 to 20 of 20
sorry, meant to include the link in my first reply.
Take a look here: https://club.myce.com/t/deciphering-the-manufacturing-date-of-your-media-with-pictures...mfgs/314571/12Last edited by Krispy Kritter; 4th Aug 2017 at 15:07.
Google is your Friend
100% Gamey...he posted the same question and media code numbers in his digitalfaq.com post. He's here because Lordsmurf threatened to close his thread due to continual pestering for answers that were already given.
Whenever he posts here, I check digitalfaq and sure enough he's being ignored or warned there and comes here.
Your name does matter since you've been banned twice, once as gamemanico, then again as gamemanico2. You then returned as samus87 and switched to mediafiles87 when it was revealed that samus87 was really gamemanico.
You're already starting with your endless questions and I have no doubt that even if you were given the answer to your original question you'd try to turn this thread into one about the effect of light, heat and humidity on your discs. Which BTW you've already posted and has been answered numerous times on this forum and digitalfaq.comLast edited by lingyi; 12th Aug 2017 at 00:43.
Your discs were made after 2015, when Ritek began MDISC production for Verbatim. The correct decade 2010s
https://www.storagenewsletter.com/2015/01/30/verbatim-to-resell-millenniata-archival-grade-m-disc/
Try both codes, one at a time.
Your discs were made by Ritek for Verbatim. Ritek is the correct choice for manufacturer.
The program is not perfect. The program cannot decipher all media hub codes. Sometimes the program will not find an answer or will give more than one answer.
JF2007730E201, Ritek, and 2010s yielded January 2012, which is not possible because Ritek did not start MDISC production for Verbatim until 2015. 15020200R0894B, Ritek, and 2010s yielded February 2, 2015, which is possible.
Your discs were made in 2015.
If you keep bumping your thread and asking questions that have already been answered, I will contact a moderator.Last edited by usually_quiet; 13th Aug 2017 at 14:36. Reason: found correct date for Verbatim-Ritek MDISC manufacturing agreement
You already asked that question at digitalFAQ. Their answer was that tests showed that M-DISC is no better than regular Verbatim when exposed to high temperature and high humidity. You are not going to receive different answers here.
Questions mdisc
By mediafiles87 in forum MediaReplies: 14Last Post: 29th Apr 2017, 13:26 -
Happy New Year to everyone at VH
By pchan in forum Off topicReplies: 0Last Post: 31st Dec 2016, 04:47 -
MDisc Thoughts for longevity?
By joshcali in forum MediaReplies: 9Last Post: 13th Dec 2015, 12:51 -
Where are you spending christmas this year?
By johns0 in forum PollsReplies: 16Last Post: 24th Dec 2014, 18:42 -
Key framing so easy a 10 year old can do it
By TreeTops in forum Off topicReplies: 4Last Post: 7th Aug 2012, 00:13
