I have not used Ripbot in a while, but now (and after some updates), have not been able to get it to run successfully even using several different video file mts sources. It completes the demuxing (valid video and audio files completed and saved in the temp folder) and reports a decoding error:
ConvertToYV12: Invalid "matrix" parameter (RGB data only) ({temp folder}\getinfo.avs, line 2)
Line 2 in getinfo.avs is:
video=DirectShowSource("T:\Temp\RipBot264temp\job1 \video.mkv",audio=false).ConvertToYV12(matrix="rec 709")
Determined that test.exe in the RipBot264\Tools\avs2yuv folder is reporting the error, which causes the conversion to stop. Same error when I tried different video files and source types. I looked in the source for avs2yuv and "rec709" appears to be a valid option.
Anyone else experiencing this or know of a solution?
Thanks,
Danno
Importing Error: avi to ripbot264
By vivabarca in forum Blu-ray RippingReplies: 2Last Post: 14th Feb 2015, 12:28 -
RipBot264 Conversion error
By FiveFingeredStyre in forum Video ConversionReplies: 6Last Post: 31st Jan 2015, 01:15 -
Importing Error: m2ts to ripbot264
By vivabarca in forum Blu-ray RippingReplies: 5Last Post: 2nd Jan 2015, 08:40 -
Error in encoding with ripbot264
By hector1980 in forum Blu-ray RippingReplies: 4Last Post: 19th May 2013, 07:19 -
mp4box error in Ripbot264..
By zanaitoryoushi in forum Video ConversionReplies: 1Last Post: 14th Sep 2012, 23:38
