Hello ,
long i search for software which will allow me create menu for video files like mkv and mp4. What i want is that something similar to blu ray or dvd menu but within file system (no reencoding only point to video file) thing that i only type name of tv show for example , choose some nice background and point to folder where episodes are and software add them to menu automaticcaly and maybe create some short preview. And maybe software will put all videofiles to one nice container.
I find out Tmngpce PMGX creator which will be nice but is outdated and more then half of my videofiles are unsuportted.
Thank you for suggestions.
Of course if you have some basic knowledge of php/MySQL you could write a simple program to list your videos and then play them in your player of choice.
But I never buy into the need for 'fancy' menus.
You could do what you want to by using a decent media player like vlc and use it's playlist function. Then you can have an on-screen list of your videos, select one for playing and it automatically selects the next one in the playlist. So you end up artificially joining the videos without actually permanently joining them which itself runs the risk of damage from re-encoding. -
Or just organize your videos so they're easy to find alphanumerically. Then you can easily navigate using a file browser like Explorer.
Best bluray authoring software for menu creation
By mulliganman in forum Authoring (Blu-ray)Replies: 30Last Post: 21st Dec 2024, 12:55 -
Best video editing software with specific filter
By andr3silva in forum Newbie / General discussionsReplies: 6Last Post: 1st Aug 2016, 12:22 -
DVD-Lab - How to link to a specific menu cell...
By main.dvd in forum Authoring (DVD)Replies: 15Last Post: 7th Feb 2015, 23:25 -
Need suggestions: Good DVD creation software with menu flexability
By Cygnus111 in forum Authoring (DVD)Replies: 6Last Post: 18th Feb 2013, 12:31 -
Blu-Ray menu creation
By magnu in forum Authoring (Blu-ray)Replies: 9Last Post: 6th Oct 2012, 16:46
