There's a "Blackmagic WDM Capture (DirectShow)" listed in capture devices, but when I select it it shows no video or audio sources, there's no preview, and most of the menu options are greyed out. I can capture fine with the software that comes with the Shuttle.
Is it possible to make this work?
Results 1 to 9 of 9
It sounds like that you may need to configure the options under the "Capture Filter" tab in Virtual Dub, selecting the appropriate input from that menu should allow you to get a signal.
I think that means the capture diver is locked to the capture hardware, or to a proprietary software module (eg, DXtory) and can't be used by VirtualDub.
I do believe there is a way to get the Shuttle to work with Virtual Dub, OP stating that a direct show device is appearing is a good sign that it does.
You might want to read through this post about configuring the device properly for use. After you configure it properly in the bundled software you may have better luck getting working in Virtual Dub. -
I'm happy to be wrong here. Thanks for following up! (not everyone does this)
It annoys the hell out of me when I Google a problem and find a forum thread that's just died off, or someone's gone 'never mind, fixed it' with no details, so I try to remember to conclude things.
I forgot once. Had the issue recur, dug up my old thread, and there was no answer.
Yes I certainly find the same thing when doing research online, a lot of people who post on forums don't realize that their conversations are being read by lots of other people in similar situations. Also the fact that these threads will appear in google searches seems to elude people, so it's great when answers get posted in threads.
Intensity Shuttle Problem.
By Bob Loblaw in forum Capturing and VCRReplies: 489Last Post: 3rd Sep 2018, 02:35 -
Elgato Game Capture HD or Black Magic Design Intensity Shuttle?
By JackSpicer0 in forum Newbie / General discussionsReplies: 1Last Post: 28th Aug 2014, 17:46 -
laptop won't recognise Panasonic BD-R disks
By henrypurcell in forum Newbie / General discussionsReplies: 3Last Post: 31st Jan 2014, 16:06 -
Blackmagic Intensity Shuttle
By mayhampixi in forum Capturing and VCRReplies: 5Last Post: 11th Nov 2013, 20:11 -
Intensity Shuttle and laptop
By Pilispring in forum Capturing and VCRReplies: 0Last Post: 11th Jan 2013, 05:02
